Téma uzavřenoAutoCAD for Mac 2017.1
Bodů: 22207
Přímý odkaz na tuto zprávu Téma: AutoCAD for Mac 2017.1
    Zasláno: 25.kvě.2017 v 14:44
Byl vydán Update 1 pro aktuální verze AutoCAD for Mac 2017 a pro AutoCAD LT for Mac 2017. Obsahuje i hotfix 2017.0.1. Ke stažení viz Download nebo Autodesk Account.
Přehled inovací a oprav:
Feature Enhancements
Palette behavior improvement
  • The Layer and Properties palettes can be floating and moved to other position.
  • The Layer palette now consists of the layer list.
  • The Layer palette shows more columns of settings by default.
  • The hight of Layer and Properties palette in Docking mode can be changed.
Touch Bar
  • AutoCAD function keys are available in the Touch Bar on the new MacBook Pro.
  • The Touch Bar is customizable.
CUI
  • The CUI dialog now differentiate the custom commands and ACAD commands. ACAD commands cannot be removed or modified.
  • CUI file schema changed.
Primary Issues Resolved by 2017.1 Update
Drawing Files
  • Characters with accents are corrupted if saved to 2004 or older DWG format.
  • Double clicking a dwg file and AutoCAD just opens a blank drawing.
  • DWG file permission changed after saved.
  • Welcomescreen does not show most recent files.
Stability Improvement
  • Crash when publish/plot some drawing.
  • Crash when switch layouts for some printers.
  • Crash when create or modify 3dpoly object.
  • Crash when start AutoCAD in some cases.
  • Crash when press CapsLock key when using some language input method on Sierra.
  • Crash when edit mleader style on MacBook with Touch Bar.
  • Crash when export PDF with override pagesetup.
  • Crash when edit color for Layer.
Others
  • Palette width is not remembered cross sessions.
  • Ghost lines in Properties palette.
  • Xref remains highlighted when switch drawings.
  • OSNAP and Polar Tracking gets disabled unexpectedly by some operations.
  • New Viewport in the context menu in layout does not work.
  • PDF attach dialog does not show the page preview.
  • Transparency icon on/off mode is not clear on status bar .
Primary issues fixed in 2017.0.1 Hotfix
  • Crashes when edit page setup.
  • Crashes when change loft settings.
  • Crashes when open or create new drawings from welcomescreen.
  • Toolset does not work when clicked.
  • Crash when customizing Toolset and restart AutoCAD.
  • Crash when refreshing commandline history.
  • Random crashes on OS X Yosemite.
  • Crash when open multiple drawings.
Tip 11441:Jak pro AutoCAD využít Touch Bar na novém MacBook Pro?
Tip 11229:Mohu používat AutoCAD LT 2015/2016 na MacOS Sierra?
Tip 8849:Kompatibilita AutoCADu for Mac s OS X 10.8 (Mountain Lion).
Tip 11691:Chyba: AutoCAD for Mac can only be installed on System drive formatted with Journaled HFS+
Tip 8392:Je AutoCAD 2012 for Mac kompatibilní s Mac OS X Lion?
Tip 7628:Kde najdu uživatelskou Support složku v AutoCADu for Mac?
Stránka byla vygenerována za 0,441 sekund.
