Over 1.119.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
Page 12> |
| Author | |
reyad102
Newbie
Joined: 08.Jun.2009 Location: Israel Status: Offline Points: 16 |
Topic: block not eraseablePosted: 04.Sep.2010 at 17:57 |
how could I make a block not eraseable in my drawing?
reyad
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 05.Sep.2010 at 17:38 |
Put it on a locked layer.
Online Portfolio: http://www.rdeweese.com/
reyad102
Newbie
Posted: 07.Sep.2010 at 15:19 |
but you can unlock that layer and erase it....I would like it not eraseable???
reyad
Cad64
Senior Member
Posted: 07.Sep.2010 at 15:51 |
You want to make it so that it can NEVER be erased??? Sorry, I don't think that's possible, and, I don't even know why you would want to do that?
Kajito
Senior Member
Joined: 29.Oct.2008 Location: Ireland Status: Offline Points: 130 |
Posted: 10.Sep.2010 at 22:11 |
well try to insert it as reference. From my experience I know that many people still do not know how to work with references and they are trying to delete such objects with no luck :))
deepu
Newbie
Joined: 07.Jun.2009 Location: United Arab Emirates Using: autocad2007 Status: Offline Points: 9 |
Posted: 13.Sep.2010 at 09:59 |
tell me why u want to protect like this. if u want to protect your file u can use password.
reyad102
Newbie
Posted: 13.Sep.2010 at 18:21 |
to enshure that no one change my dwg.
reyad
Cad64
Senior Member
Posted: 14.Sep.2010 at 02:45 |
There is software out there that will supposedly lock a drawing, making it uneditable. You might want to check out that option. The program I'm referring to is called CadLock. Google it for more information.
haithamsitto
Newbie
Joined: 14.Sep.2010 Location: United States Using: Acad2010 Status: Offline Points: 3 |
Posted: 14.Sep.2010 at 04:54 |
I have never run into a situation where a file provided to me was not changeable. Even as a reference, the block has to be available to reference. If you have a concern about your drawing not being changed, don’t share it in a cad format, send a pdf file. Even those can now be vectorized and changed as needed if your know how to do it. We do this all day long because the clients provide us with paper line drawings. |
jmattingly
Newbie
Posted: 14.Sep.2010 at 23:48 |
When you create the block, there is a setting, so it will not explode. Just click on the box in your block editor. Hope this helps. J
Post Reply
Page 12> |
Tweet
This page was generated in 0,094 seconds.
block not eraseable
Topic Options
