RSS discussions
Discussion Discussion forum
Topic ClosedInsert Command Crashes
 Post Reply Post Reply
Author
pweeks View Drop Down
Groupie
Groupie
Using: AutoCAD 2017
Status: Offline
Direct Link To This Post Topic: Insert Command Crashes
    Posted: 26.Aug.2014 at 22:34
For some reason anytime I try to insert a block into my drawing the program completely stops, I can't click, move, edit or exit out of the program while in the command. The program doesn't completely crash because I can still hit ESC and everything will be back to normal. It's almost as if the command is functioning properly but the insert box will not appear.
I originally made these blocks in our old 2008 program on a master template dwg and we recently upgraded to 2013. It'll work on my coworkers computers but not mine.
I know it can still see/read the blocks because when I enter the BLOCK command to make a new one I can see them on the drop down bar. Does anyone know how I can either fix my insert command or can directly enter the block editor so I can at least copy/paste what I need from there?
Thanks
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Aug.2014 at 00:04
Why don't you just do a REPAIR of the installation and see if that fixes the problem?
FYI - A Repair is NOT the same as an uninstall/reinstall.  It's the least invasive choice and not the nuclear choice.  Got it?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2017
Status: Offline
Direct Link To This Post Posted: 27.Aug.2014 at 00:20
I will give that a try. I will need to let my boss know since I am not the acting administrator. Thanks for the suggestion.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 27.Aug.2014 at 07:20
Hello pweeks, we recently moved from Autocad 2008 to 2012 and we had some problems with file that we couldn't open on anything else than FATAL ERROR.
I did an AUDID on all them and had errors repairs but 1 wasn't OK.
I had to open it with an other CAD program ( DRAFTSIGHT ) and do 27 copy/paste to paste the model and paper spaces ( 27 pages of a big 3D procedure ).
This was OK after then but exhausting !
I think that an AUDIT on each problematic file would be the solution.
Do a SAVE just before inserting a file for some time.
Do you have a crash on each 2008 file that you insert?
Edited by philippe JOSEPH - 27.Aug.2014 at 07:22
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Aug.2014 at 11:49
If the blocks work on the coworker's computer (as per OP's original post) then my guess is AUDIT will do nothing to solve the problem.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 27.Aug.2014 at 12:49
John, yes you are right ( as usual ) I did an AUDIT + RECOVER.
Edited by philippe JOSEPH - 27.Aug.2014 at 12:51
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,254 seconds.
