RSS discussions
Discussion Discussion forum
Topic ClosedReplace with MVIEW-block?
 Post Reply Post Reply
Author
Kerston_Mo View Drop Down
Newbie
Newbie
Using: civil 3d 2011
Status: Offline
Direct Link To This Post Topic: Replace with MVIEW-block?
    Posted: 01.Nov.2015 at 13:15
Hi! I am looking for a LISP to replace 2D-blocks in a file (more than 1900 pcs of the same one block) with an Mview-block instead. Any ideas?
1900 thanks in advance!
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Nov.2015 at 20:21
What is a Mview block?
<<AutoCAD 2015>>
Back to Top
edwinprakoso View Drop Down
Groupie
Groupie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Posted: 02.Nov.2015 at 05:30
MVIEW block is multi view block. Only available in verticals like AutoCAD MEP. Basically the block has different views, from top, front, back, left and right. So when you create elevation view or section view, the software will use show appropriate view for that particular block.
I don't use them frequently and long enough... so I don't know if that's possible.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
