Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
martingtc
Groupie
Joined: 17.Jun.2016 Location: United Kingdom Using: 2008LT Status: Offline Points: 28 |
Topic: Hatch Creation HelpPosted: 21.Dec.2017 at 16:52 |
Can someone please help me? I've drawn a 1m x 1m square and need the hatch inside as a .pat but I just can't work it out :( can someone help?
Super thanks.uploads/657554/dm.dwg
Breeze104
Senior Member
Joined: 03.Aug.2007 Location: United States Using: Production Design Suite Premium 2015 Status: Offline Points: 125 |
Posted: 21.Dec.2017 at 17:13 |
Can you upload a screen shot of what "you" are getting? Because when I opened the dwg it was total hatched.
Breeze |
martingtc
Groupie
Posted: 21.Dec.2017 at 17:59 |
Sorry, that's how I want the hatch to look - a diamond pattern with thick bars. I've drawn the end product but need a hatch for it please
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 21.Dec.2017 at 18:07 |
So you want someone here to create a custom hatch pattern. What are you willing to pay?
Edited by John Connor - 21.Dec.2017 at 18:21 |
<<AutoCAD 2015>> |
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 21.Dec.2017 at 20:37 |
I happen to have one quite similar to that:
*LATT60,LATTICE-WORK AT 60 DEGREES, 1" SLATS, 3" GAPS 60,0,0,0,4 60,1.1547,0,0,4 120,0,0,2.3094,4,3.4641,-1.1547 120,1.1547,0,2.3094,4,-1.1547,3.4641 Are you capable of figuring out how to alter that for your size and proportions? Also, you will need to decide whether the 70x120 diamond dimensions are the critical thing, or an actual 60-degree angle is wanted [yours is only about 1/4 of a degree off of 60]. If the former, the angle designators above will have to be changed as well as the offsets and pen-down/pen-up numbers. If the latter, the angles above are good.
martingtc
Groupie
Posted: 22.Dec.2017 at 09:15 |
Pefect!! that's awesome. I have another which is the same, but 100 across and 170 top to bottom. Which valus would I change on the txt file?
Thank you Edit: actually, it's a bit off - the bars are 20 when they need to be 32 :(
Edited by martingtc - 22.Dec.2017 at 11:38 |
Kent Cooper
Senior Member
Posted: 22.Dec.2017 at 15:41 |
You can make your own, at whatever sizes and/or proportions and/or angles you want. Read about it in Help [>>here<< for 2018, but no different for earlier versions], draw up your specifics in a limited area, and use the image for what values to put where in the pattern definitions.
Edited by Kent Cooper - 22.Dec.2017 at 15:45 |
Post Reply
Tweet
This page was generated in 0,131 seconds.
Hatch Creation Help
Topic Options
