RSS discussions
Discussion Discussion forum
Topic Closedproblem in autocad
 Post Reply Post Reply
Author
silkambu View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Topic: problem in autocad
    Posted: 23.Dec.2008 at 11:28
hello everybody,
please solve my problem , i am having a problem when i copy somthing from one file to other file , also when i save my file ,  there is "ARX_ERROR: eNotThatKindOfClass "    massage comes. i do not know why it happen. please solve my proble.
please tell me what is the solution.
Thanks
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 23.Dec.2008 at 12:02
Are there any messages when checking the drawing with AUDIT/RECOVER?
See also the tip:
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2008 at 12:13
thanks for reply,
but i am faceing same problem while i m saving . when i do save i can see on command prompt "ARX_ERROR: eNotThatKindOfClass"
i do not know what to do. please help me.
Thanks
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 23.Dec.2008 at 14:41
Originally posted by silkambu silkambu wrote:
thanks for reply,
Thanks
I advice  this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7047371&linkID=9240618
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Apeiron View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2008 at 15:08
SILKAMBU .... your problem it's because you are working in a dwg file created in a newest version that you work now ( for example if the objects are made in 2008 and you take this dwg file and start to work , lets say in 2005 ... everytime when you want to copy something in this dwg file or to make something the autocad 2005 version it's giving you this message).
The solution is to open again in 2008 or 2009 and DO NOT MAKE    SAVE AS ... but to export in 2004 format or 2006 how you work and in this moment the autocad (2009 or 2008) is converting all the abjects created in the version you want and you will not have this message again.
I think it was made with Civil 3D 2008 or 2007 ????? Wink .... anyway the export function is under FILE somewhere down ... lock carefully and you will find ... good luck and a Merry Christmass and a Happy New Year to all the autocad users from this forum
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron
Back to Top
johnnycad View Drop Down
Newbie
Newbie
Using: autocad 2007 , archicad 12
Status: Offline
Direct Link To This Post Posted: 30.Dec.2008 at 02:00
it's export not save to older verison in pull down (my mistake)  in U.S.A
Edited by johnnycad - 05.Jan.2009 at 03:16
Back to Top
msplcdykee69 View Drop Down
Senior Member
Senior Member
Using: Civil 3D, Map, Inventor, Mechanical, & Electrical
Status: Offline
Direct Link To This Post Posted: 30.Dec.2008 at 20:10
Did you install the object enabler add on for your version of AutoCAD?  We had that problem when we used LDD 2004 and other firms went to 2006 Civil 3D We installed the object enabler for our version and it solved our problem.
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 05.Jan.2009 at 01:25
No johnycad ...... you didn't read very well what I wrote .... it's not ood to use SAVE AS because with special objects created in a specialized version you will have problems.
You have to make from the same version where you created these objects EXPORT ..... I repet .... no SAVE AS
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,229 seconds.
