Over 1.127.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
| Author | |
silkambu
Groupie
Joined: 30.Jan.2008 Location: United Kingdom Status: Offline Points: 23 |
Topic: problem in autocadPosted: 23.Dec.2008 at 11:28 |
hello everybody,
please solve my problem , i am having a problem when i copy somthing from one file to other file , also when i save my file , there is "ARX_ERROR: eNotThatKindOfClass " massage comes. i do not know why it happen. please solve my proble.
please tell me what is the solution.
Thanks
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 23.Dec.2008 at 12:02 |
Are there any messages when checking the drawing with AUDIT/RECOVER?
See also the tip:
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
silkambu
Groupie
Posted: 23.Dec.2008 at 12:13 |
thanks for reply,
but i am faceing same problem while i m saving . when i do save i can see on command prompt "ARX_ERROR: eNotThatKindOfClass"
i do not know what to do. please help me.
Thanks
Arben.Allaraj
Senior Member
Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 23.Dec.2008 at 14:41 |
I advice this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7047371&linkID=9240618 |
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
Apeiron
Groupie
Joined: 30.Aug.2007 Location: Romania Status: Offline Points: 74 |
Posted: 23.Dec.2008 at 15:08 |
SILKAMBU .... your problem it's because you are working in a dwg file created in a newest version that you work now ( for example if the objects are made in 2008 and you take this dwg file and start to work , lets say in 2005 ... everytime when you want to copy something in this dwg file or to make something the autocad 2005 version it's giving you this message).
The solution is to open again in 2008 or 2009 and DO NOT MAKE SAVE AS ... but to export in 2004 format or 2006 how you work and in this moment the autocad (2009 or 2008) is converting all the abjects created in the version you want and you will not have this message again.
I think it was made with Civil 3D 2008 or 2007 ?????
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron |
johnnycad
Newbie
Joined: 02.Aug.2007 Location: United States Using: autocad 2007 , archicad 12 Status: Offline Points: 2 |
Posted: 30.Dec.2008 at 02:00 |
it's export not save to older verison in pull down (my mistake) in U.S.A Edited by johnnycad - 05.Jan.2009 at 03:16 |
msplcdykee69
Senior Member
Joined: 15.Dec.2008 Location: United States Using: Civil 3D, Map, Inventor, Mechanical, & Electrical Status: Offline Points: 163 |
Posted: 30.Dec.2008 at 20:10 |
Did you install the object enabler add on for your version of AutoCAD? We had that problem when we used LDD 2004 and other firms went to 2006 Civil 3D We installed the object enabler for our version and it solved our problem.
Apeiron
Groupie
Posted: 05.Jan.2009 at 01:25 |
No johnycad ...... you didn't read very well what I wrote .... it's not ood to use SAVE AS because with special objects created in a specialized version you will have problems.
You have to make from the same version where you created these objects EXPORT ..... I repet .... no SAVE AS |
Post Reply
Tweet
This page was generated in 0,066 seconds.
problem in autocad
Topic Options
silkambu wrote:
