RSS discussions
Discussion Discussion forum
Topic ClosedCad2004 problem
 Post Reply Post Reply
Author
ameralmayahi View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Cad2004 problem
    Posted: 24.May.2009 at 03:31
Hi Guys,
 A year ago I had created AutoCad 2004 files, now I can't open them on my computer,any idea?
I 'm getting a message saying " couldn't open the specify file". Even I can't preview them before opening them.
Thanks
Back to Top
tkelly View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 24.May.2009 at 07:53
I think you made some damage to the file or that file was opened with higher version of AutoCAD and was not saved back to previous version.
Try opening with higher version of Autocad.
Check the size of file does that file . If it is leass tahn 10 KB or so then the file is corrupted.
Tom
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 24.May.2009 at 16:19
Hii tkelly,
Thanks for your response.
I have checked the files size and there were all more than 100Kb.
I had created them in Autocade2004 and I tried to open them in AutoCad2004 as well.
Back to Top
AmerieWhite View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.May.2009 at 14:57
Try to 'recover' the drawing in AutoCAD or try this converter to repair the drawing file:
AutoDWG DWG DXF Converter (http://www.autodwg.com/DWG_DXF_Converter/)
With this converter, you just need to add the draiwng in the list, choose version conversion and output 2004 version. with clicking on convert button, drawing file in 2004 version will be generated.
Edited by AmerieWhite - 26.May.2009 at 15:33
Amerie White
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 27.May.2009 at 01:08
Thanks a lot brother Amerie White,
I have tried the program you sent me but I'm keep getting the message (attached snap shot) every time I want to access to the CAD files.
Please see the attached file on the following link:
http://rs517.rapidshare.com/files/237604743/1.bmp
Please any advice?
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 09.Jun.2009 at 04:58
It seems there is something to do with the path name. You can try to put the draiwng on Desktop and see if it works.
Amerie White
Back to Top
asli.dost View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 17.Jun.2009 at 05:31
Try to open drawing in autocad 2007.but open autocad 2007 and recover seclet file and start recovering .I think your file will be recover and save other location and change file type change .Autocad2007
Try and enjoy
asli
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 19.Jun.2009 at 22:10
Dear asli.dost /Newbie
Thank you a lot for your solution
I applied it and it worked well !!Clap
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,148 seconds.
