RSS discussions
Discussion Discussion forum
Topic ClosedDXF read problem!!!
 Post Reply Post Reply
Author
spklive View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: DXF read problem!!!
    Posted: 18.Aug.2009 at 22:48
Thanks for the reply!!
I' ll try and other CAD programs!!
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 18.Aug.2009 at 22:38
I see - the "multi format" refers to that the DXF format is usable in multiple appliactions. Both DXF and 3DS files are Autodesk formats and they should be readable in AutoCAD.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.Aug.2009 at 21:54
Thanks for the reply Vladimir!!Smile
Maybe you have right! This model i downloaded http://www.fallingpixel.com/3d-models/11061
i opened .3ds!
3ds is the same with .dxf? Is there any difference?
I'm not familiar with CAD!! I need this file to be exported to .sat, to open with CFD programs!! But when i export .3ds there is a message that says the items i selected are not solids!
Do you have any idea?
Thanks friend!!!
Back to Top
Moderator Group
Moderator Group
Arkance Systems CZ
Status: Offline
Direct Link To This Post Posted: 18.Aug.2009 at 21:45
It is probably a file in a different file format (just the same extension). There is no "multi format" for AutoCAD DXF files.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.Aug.2009 at 21:42
Hi guys,
I need your help!!!
I downloaded a cad file (.DXF multi format) from internet. I use AutoCAD 2002 but when i open this file there is the message: "the file is currently in use or is read-only. Would you like to open the file read-only?" I press "yes" and then AutoCAD writes "improper the entry name LUCE.1 on line.86. Invalid or incomplete DXF input-drawing discarded." and it doesn't open!!!
I don't know what happens?Confused
what is DXF multi format???
Can anyone help me??
Thanks!!!!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,063 seconds.
