RSS discussions
Discussion Discussion forum
Topic Closed'Flatland' LT 2002
 Post Reply Post Reply
Author
bdxmw View Drop Down
Newbie
Newbie
Using: Autocad 2013 LT
Status: Offline
Direct Link To This Post Topic: 'Flatland' LT 2002
    Posted: 10.Sep.2012 at 13:05
in the 2002 version of autocad LT there was a command called 'flatland' this was created by using a macro. this command was extremly helpful when recieving drawings based on a 3d survey. i have not been able to find this command in any version of autocad LT to date or any way of creating this command.
could anybody help?
regards bdx
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 10.Sep.2012 at 14:32
Hello, if I understand your needs, you want to flatten all the objects of a 3D file so that you can use them in a 2D file.
It's possible if you do the following sequence :
Move the objects, choose "all", from point : 0,0 to 0,0,1E99.
Then :
Move the objects, choose "all" , from point : 0,0,1E99 to 0,0,0.
beware of doing it with a general UCS.
Take a 3D point of view other than the standard plan view ( left for example ) to check if all is OK.
This won't flatten the objects in a bloc or in an Xref.
It's also possible to move objects to Z:0 in the properties pannel  (Ctrl+1 ) but only by families of object ( not OK with lines and arcs ).
Ask for more, tell us if this has solved your problems.
Are you familiar with a 3D work on AutoCAD ?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,096 seconds.
