RSS discussions
Discussion Discussion forum
Topic ClosedBLOCK EDITOR UNITS AND UCS
 Post Reply Post Reply
Author
DONOAKI View Drop Down
Newbie
Newbie
Using: autocad2010
Status: Offline
Direct Link To This Post Topic: BLOCK EDITOR UNITS AND UCS
    Posted: 12.Aug.2008 at 15:51
Hi!  I`m new in the forum.
I have a question about the block editor of the acad 2008. The thing is that when I edit and save something with the block editor (the one with the yellow background), the units of the drawings goes to milimiters and the UCS goes to unknown. I Don´t know if it´s something in the configuration of the block editor or something in the creation of the block. This doesn´t happen if I edit the block reference in place.
Any clue is well received!!
thanks!
donoaki
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 12.Aug.2008 at 21:37
thanks!
donoaki
I got some little help see in AutoCAD help for more.
A UCS icon is displayed in the drawing area of the Block Editor. The origin of the UCS icon defines the base point for the block. You can change the base point for the block by moving the geometry relative to the origin of the UCS icon, or by adding a base point parameter.
The UCS command is disabled in the Block Editor. You can open an existing 3D block definition in the Block Editor and assign parameters to the block. However, the parameters will ignore any Z coordinate values in the block space. Consequently, the block reference cannot be edited along the Z axis. Furthermore, while you can create a dynamic block that contains solid objects and add actions to it, such as move, rotate, and scale, you can't perform solid editing features within a dynamic block reference (for example, stretch a solid, move a hole within a solid, and so on).
So I think it is about your ucs.
Edited by Arben.Allaraj - 12.Aug.2008 at 21:40
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Newbie
Newbie
Using: autocad2010
Status: Offline
Direct Link To This Post Posted: 13.Aug.2008 at 15:03
Thank you for the quik answerd. I know wath you said about the ucs in the block editor and the Z coordinate.
But my problem is this: I usually work with the drawing in meters, and, in the model, i use the convenient UCS depending on what i'm drawing. But when i open the block editor, and then go back to the model, the units of the drawing goes to milimeters, and the ucs in use goes to a new "unknown" ucs.
So the basic problem is that the drawing units are change in the entire drawing, and i need to work in meters so that the drawins fix in others drawings.
thanks!
and I hope i can express my self clear!
donoaki
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,090 seconds.
