  Visitors: 8108
CAD tip CAD tip # 10761:
Dynamic block attributes do not respect visibility states.
A - answer Non-constant attributes of dynamic block yield to display control through "visibility states" (and other dynamic actions) only of they are locked.
In the dynamic block editor, open the Properties palette (Ctrl+1) and set the property "Lock position" (the last row) for the given attribute to Yes. Then Attsync the changed block.
ACAD
23.2.2016    6983×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13452:HideItem - hiding individual items in AutoCAD arrays
Tip 12172:How to show or hide an object in all visibility states?
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11896:How to drive dyn.block parameters or constraints from Excel?
Tip 11439:Replace block instances (incl. dynamic) with another block.
