  Visitors: 1957
CAD tip CAD tip # 11581:
How to compare changes between two versions of a Revit BIM project?
A - answer One of the functions of the cloud application Autodesk BIM 360 Team is comparing differences between two versions of a project (RVT). Choose a document with more versions and under the version number field pick the function "Compare versions".
This function lists and highlights (in color) all added, removed and changed objects in bothe versions of the project. In the sample: version 2 contains a moved table (highlighted), slightly moved cabrio in the garage, added a partition wall, deleted tree/shrub.
Version Diference
You can display numerical and parametrical details of the changes performed:
List of all changes can be exported to a CSV file for Excel.
See also a sample video:
RevitBIM360Team
28.8.2017    5849×
Prices - CAD eShop:
applies to: Revit · BIM360 · BIM360/Fusion Team ·
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12406:How to log out automatically from your Autodesk account after closing an app?
Tip 12314:How to display OBJ models including textures in A360?
Tip 11600:How to rename a project in BIM 360 or Fusion Team?
Tip 10923:Which Autodesk products do support the IFC format?
