Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8807:
Question
The number of points contained in a points cloud depends on the scanning sampling. The max number of points displayed in in a drawing is controlled by the system variable POINTCLOUDPOINTMAX.
The default value is 1500000 points (1.5 million). The maximum number of points that can be displayed for all point clouds attached in the current AutoCAD session is 10 million for 64-bit systems and 5 millions for 32-bit systems (x86).
ACAD2013
6.9.2012    7834×
Share the tip:
applies to: AutoCAD 2013 ·
Tip 14496:Convert scanned point clouds or photos to BIM objects - Scan-to-BIM.
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Back    All CAD Tips
Categ:
