  Visitors: 3988
CAD tip CAD tip # 6419:
MAP2SDF problem: Could not open FDO connection - SDF version 2.1, not 3.
A - answer After you export a SDF2 file from AutoCAD Map or Civil using the MAP2SDF command, the resulting file cannot be read over the FDO. The error displayed is:
Could not open FDO connection.
SDF file appears to be version 2.1 or older. Please convert to SDF version 3.
The Autodesk FDO provider for SDF does not support the old SDF2 format. For the SDF 3 format use the new AutoCAD Map command: MAPDWGTOSDF. You can use it also to convert an existing SDF 2 file to version 3.
To batch convert multiple SDF2 files to SDF3 you can use the option "Load procedure" in MapGuide Studio (version 2007 or higher).
Map2009Civil2009MapG
4.12.2008    10211×
Prices - CAD eShop:
applies to: AutoCAD Map 3D 2009 · Civil 3D 2009 · MapG ·
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 9333:Which CAD and BIM formats are supported in Autodesk Robot Structural Analysis 360?
Tip 9149:Total area of selected regions or hatches (by layer) - AddArea
Tip 8932:HEC-RAS Import/Export in higher versions of AutoCAD Civil 3D.
Tip 8496:Import a XYZ-coordinate file as AutoCAD points with labels.
VRMLout More info
