  Visitors: 4757
CAD tip CAD tip # 8181:
Rounding decimal numbers in drawing texts.
A - answer If you need to round decimal numbers in drawing texts in AutoCAD DWG drawings, you can use the free utility CADstudio RoundT.
Download the add-on application from Download, load it with APPLOAD and run the RoundT command. After you select the texts, the command prompts for the number of decimal places to round. All selected texts (DText/MText and block attributes) which are pure decimal numbers will be rounded to the specified number of decimal places:
The application supports both point and comma as the decimal separators. A negative number of decimal places means that also the trailing zeroes will be displayed.
Using RoundT:
Since version 1.3 you can also use the command ROUNDT2 to round any decimal numbers inside longer strings and MText codes. Or use NumInText.
ACAD
1.9.2011    18224×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
Tip 13408:How to increment the numbers in DWG texts by a specified value, e.g. +1, +10?
Tip 13221:Attractor - snap multiple objects to existing points/vertices.
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 12777:Arithmetic and trigonometric functions available in Revit expressions.
