fantomas
Přihlášen: 08.dub.2008 Lokalita: ČR (Pha) Používám: autoCAD archiCAD Stav: Offline Bodů: 2 |
Téma: instalace autoCADU 2007Zasláno: 08.dub.2008 v 22:12 |
dobry den muze mi prosim nekdo poradit vzdy kdyz instaluji autoCAD 2007 ´tak mi to v prubehu instalace nahlasi chybu a ze se mam podivat na nejake informace kterym totalne nerozumim. zde prikladam:2008/4/8:22:05:08 fantomas HOME-5229C73621 === Installation started on HOME-5229C73621 by fantomas ===
2008/4/8:22:05:10 fantomas HOME-5229C73621 Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4000.4039 2008/4/8:22:05:10 fantomas HOME-5229C73621 Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0 2008/4/8:22:05:10 fantomas HOME-5229C73621 Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required 2008/4/8:22:05:29 fantomas HOME-5229C73621 Install DirectX 9.0 Runtime Succeeded Command = "C:\Documents and Settings\fantomas\Plocha\AutoCAD 2007 with CRACK\Bin\AcadFEUI\support\DirectX\DXSETUP.exe" /silent 2008/4/8:22:05:29 fantomas HOME-5229C73621 Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1117.0 2008/4/8:22:05:49 fantomas HOME-5229C73621 Install Autodesk DWF Viewer Succeeded Command = "C:\Documents and Settings\fantomas\Plocha\AutoCAD 2007 with CRACK\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0 2008/4/8:22:05:49 fantomas HOME-5229C73621 Install Flash User cancelled 2008/4/8:22:05:49 fantomas HOME-5229C73621 === Installation ended === nemuze mi nekdo prosim poradit jak na to? mam win xp a muj notebook myslim ze bohate zvlada hardwarove pozadavky predem dekuji za radu Upravil fantomas - 09.dub.2008 v 20:27 |
Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: řešení Autodesk Stav: Offline Bodů: 22233 |
Zasláno: 08.dub.2008 v 22:33 |
Nehlásí to chybu 1406? Viz tipy.
Ferdinand
Zasláno: 09.dub.2008 v 13:16 |
Pokud se pokoušíte instalovat SW nelegálně (nekoupený), porušujete jednak pravidla tohoto fóra a jednak zákony. Pan Michl se mnou jistě souhlasí...
Upravil Ferdinand - 09.dub.2008 v 13:17 |
fantomas
Zasláno: 09.dub.2008 v 15:45 |
ja si naprosto uvedomuji ze je to nelegalni a poru tim snad uplne vse co na tomto foru je, ale bohuzel jakozto student nemam na zakoupeni a jsou nyni problemy k licenci na studentskou verzi coz jakmile se tento problem vyresi ihned odstranuji nelegalni kopii vlastne neodstranuji jelikoz mi tam nejde. nyni mi ale slape na paty termin do odevzdani projektu a ja ho bohuzel nemam jak vypracovat proto jsem sahl po teto nelegalni moznosti za kterou se stydim |
nyms
Přihlášen: 04.říj.2006 Lokalita: ČR (HK) Používám: Inventor, Autocad Stav: Offline Bodů: 6 |
Zasláno: 11.dub.2008 v 07:55 |
jako student máte možnost získat legálně dvouletou studentskou licenci na řadu produktů Autodesku včetně Autocadu 2007 a 2008 - http://www.autodeskclub.cz/club/licence.aspx.
Je ovšem možné, že i s legálním softwarem budete mít při instalaci problémy, pak si prostudujte informace na webu http://nyms.spsnome.cz |
Stránka byla vygenerována za 0,238 sekund.
