Téma uzavřenoinstalace autoCADU 2007
fantomas Zobrazit panel
Přihlášen: 08.dub.2008
autoCAD archiCAD
Bodů: 2
Přímý odkaz na tuto zprávu Téma: instalace autoCADU 2007
    Zasláno: 08.dub.2008 v 22:12
dobry den muze mi prosim nekdo poradit vzdy kdyz instaluji autoCAD 2007 ´tak mi to v prubehu instalace nahlasi chybu a ze se mam podivat na nejake informace kterym totalne nerozumim.
zde prikladam:2008/4/8:22:05:08 fantomas HOME-5229C73621 === Installation started on HOME-5229C73621 by fantomas ===
2008/4/8:22:05:10 fantomas HOME-5229C73621 Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4000.4039
2008/4/8:22:05:10 fantomas HOME-5229C73621 Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2008/4/8:22:05:10 fantomas HOME-5229C73621 Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2008/4/8:22:05:29 fantomas HOME-5229C73621 Install DirectX 9.0 Runtime Succeeded   Command = "C:\Documents and Settings\fantomas\Plocha\AutoCAD 2007 with CRACK\Bin\AcadFEUI\support\DirectX\DXSETUP.exe" /silent
2008/4/8:22:05:29 fantomas HOME-5229C73621 Install MDAC 2.7 Skipped MDAC upgrade is not required. System Version = 2.81.1117.0
2008/4/8:22:05:49 fantomas HOME-5229C73621 Install Autodesk DWF Viewer Succeeded   Command = "C:\Documents and Settings\fantomas\Plocha\AutoCAD 2007 with CRACK\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2008/4/8:22:05:49 fantomas HOME-5229C73621 Install Flash User cancelled
2008/4/8:22:05:49 fantomas HOME-5229C73621 === Installation ended ===
nemuze mi nekdo prosim poradit jak na to? mam win xp a muj notebook myslim ze bohate zvlada hardwarove pozadavky predem dekuji za radu
Upravil fantomas - 09.dub.2008 v 20:27
Bodů: 22229
Přímý odkaz na tuto zprávu Zasláno: 08.dub.2008 v 22:33
Nehlásí to chybu 1406? Viz tipy.
Bodů: 1919
Přímý odkaz na tuto zprávu Zasláno: 09.dub.2008 v 13:16
Pokud se pokoušíte instalovat SW nelegálně (nekoupený), porušujete jednak pravidla tohoto fóra a jednak zákony.  Pan Michl se mnou jistě souhlasí...
Upravil Ferdinand - 09.dub.2008 v 13:17
autoCAD archiCAD
Bodů: 2
Přímý odkaz na tuto zprávu Zasláno: 09.dub.2008 v 15:45
ja si naprosto uvedomuji ze je to nelegalni a poru tim snad uplne vse co na tomto foru je, ale bohuzel jakozto student nemam na zakoupeni a jsou nyni problemy k licenci na studentskou verzi coz jakmile se tento problem vyresi ihned odstranuji nelegalni kopii vlastne neodstranuji jelikoz mi tam nejde. nyni mi ale slape na paty termin do odevzdani projektu a ja ho bohuzel nemam jak vypracovat proto jsem sahl po teto nelegalni moznosti za kterou se stydim
nyms Zobrazit panel
Přihlášen: 04.říj.2006
Inventor, Autocad
Bodů: 6
Přímý odkaz na tuto zprávu Zasláno: 11.dub.2008 v 07:55
jako student máte možnost získat legálně dvouletou studentskou licenci na řadu produktů Autodesku včetně Autocadu 2007 a 2008 - http://www.autodeskclub.cz/club/licence.aspx.
Je ovšem možné, že i s legálním softwarem budete mít při instalaci problémy, pak si prostudujte informace na webu http://nyms.spsnome.cz
Tip 5578:VIPChyba 1603 při instalaci CAD aplikace - příčiny.
Tip 4677:VIPInstalace FlexLM/FlexNet serveru z AutoCADu 2006/2007 pod Windows NT4.
Tip 4311:VIPInstalace aplikací rodiny AutoCAD 2006/2007 ve Windows XP 64-bit.
Tip 11626:VIPExport kusovníku v Inventoru - Nelze vytvořit soubor: Exporty databáze vyžadují instalaci 64bitové verze systému Microsoft Office.
Tip 5292:VIPInstalace driveru PowerDraft na lokalizovaných produktech řady 2007.
Tip 5382:Je Internet Explorer 7 kompatibilní s AutoCADem?
