Děkujeme za účast na konferenci CADfórum 2025 - podívejte se na reportáž
Přes 120.000 registrovaných u nás, celkem 1.107.000 registrovaných (CZ+EN), přes 53.000 CAD/BIM bloků. Vyzkoušejte nový přesný Kalkulátor, vylepšený Převodník jednotek a proměnné prostředí AutoCADu.
Téma uzavřenoUveden SP2 pro Mechanical 2015
Bodů: 22041
Přímý odkaz na tuto zprávu Téma: Uveden SP2 pro Mechanical 2015
    Zasláno: 30.zář.2014 v 12:35
Byl uveden Service Pack 2 pro AutoCAD Mechanical 2015 - viz Download.
Přehled oprav v SP2 (kromě oprav jádra AutoCADu):
Bill of Materials (BOM)
Service Pack 2
  • Redundant row is created in the BOM after pasting a block.
Dimension
Service Pack 2
  • When using legacy Power Dimensioning dialog, specifying "+" in front of a value for upper tolerance will cause program to terminate and exit.
Symbols
Service Pack 2
  • Symbol attached to dimension gets shifted after a REFEDIT on the block.
  • Symbol attached to dimension gets shifted after running a script.
AMSETUPDWG
Service Pack 2
  • On a secondary user login, objects with note symbol cannot be copied/pasted after running AMSETUPDWG.
  • On a secondary user login, zig zag lines disappear after running AMSETUPDWG.
Mechanical Layer
Service Pack 2
  • In some drawings, objects do not show up even after setting the layer to ON.
Section View
Service Pack 2
  • Excluded characters for the identifier still show up when creating the section view.
Detail View
Service Pack 2
  • Error message in the command line when trying to REFEDIT a block (that contains content) inside a detail view.
  • Crosshair disappears at the second prompt to specify the detail view circle/rectangle.
  • Scale "1:3" is showing as "1.3.0303".
Tip 4457:VIPAplikování Mechanical 2005 Service Pack na síťový obraz instalace.
Tip 2080:Je Mechanical Desktop v Inventor Series totéž co MDT6 se Service Packem 2?
Tip 4334:Nelze nainstalovat Mechanical 2005 pod Windows XP SP2.
Tip 10153:Chyba "You do not appear to have any language database files installed." v Simulation Mechanical.
Tip 9732:Produkty Autodesk oficiálně kompatibilní s Windows 8.
Tip 9890:Po otevření výkresu ze starší verze Mechanicalu se posune popiska detailu.
Stránka byla vygenerována za 0,379 sekund.
