Téma uzavřenoECSCAD 2015 SR3
Bodů: 22240
Přímý odkaz na tuto zprávu Téma: ECSCAD 2015 SR3
    Zasláno: 29.čvc.2015 v 22:30
Uvolněna Service Release 3 pro ECSCAD 2015 - viz Download.
Přehled oprav:
• 1500: S603 Modify signal XRef in DataEditor is not working
• 1460: S582 Wago Interface do not use terminal numbers if multitier terminals are used
• 1459: S580 Wago Interface fails with multitier terminals
• 1477: S600 GL does not support path with "\"--> not allowed
• 1226: Vault: Settings are not persistent after restarting ecscad.
• 1452: S573 NO_LOC in devices
• 1450: S571: function text isn’t translated in graphical terminal plans
• 1457: S579 Command ECS_COPY_MULTIPLE fails, does not set lines Online
• 1454: S566 Copy INST without ONLINE control fails
• 1356: S466 PS1 with double attribute 600 occurs problem
• 1451: S570 System path: CONFIG must be located on the first place
• 1448: S567 QuickPick Symbol/Macro name manual input max 31 Char. must be 32
• 1381: S542 Access-Reports ->Wire List -> wrong filter
• 1439: S552 PM: cut/paste INS from Folder to Root not working
• 1391: S529 Additional Path in PM for Check In/Out
• 1354: S476 several GS1 symbols with identical DevID ID Display Page-DevID-Line No.
• 1363: S498 GL: several problems with GL's
• 1436: S559+563 Moving cursor over PM, actual command is canceled
• 1437: S553 length (characters) of INS, LOC and Folder limited to 32 characters as sum
• 1438: S553 open last page length on start screen fails with 32 characters problem
• 1440: S561 Double Prefix (== or ++) on BMK if "." in INS or LOC
• 1442: Performance: Zoom of a page forces ecscad to write page
• 1373: S513 PM: drawings containing a dot in the drawing name will not be recognized
Tip 8908:AutoCAD ecscad 2013 nezobrazuje logo v razítku.
Tip 7705:Načtení projektů Eplan do AutoCAD ecscad.
Tip 9432:Jak spustit ECSCAD jako holý AutoCAD?
Tip 8083:Vestavěný překladač - vícejazyčné popisky v AutoCADu ecscad.
Tip 10313:Postup nastavení licence aplikace ECSCAD
Tip 10131:Jak do ECSCADu načíst projekt z E-CADů nebo z EPLAN 5?
Stránka byla vygenerována za 0,422 sekund.
