Téma: SP1 pro AutoCAD 2017Zasláno: 23.čvc.2016 v 18:07 |
Byl uveden Service Pack 1 pro rodinu produktů AutoCAD 2017. Ke stažení v Desktop App nebo na stránce Download. Přehled oprav v SP1:
Blocks • There were occasional crashes when inserting some blocks a second time. Graphics • There were occasional crashes when zooming out of a drawing following the 3D orbit command. Purge • There were occasional crashes when purging DXF drawing files. Web and Cloud • There were occasional crashes when modifying the Online Options settings and signing in to Autodesk A360 from InfoCenter. General • There were occasional crashes when launching AutoCAD in Windows 10. • There were occasional crashes when inputting the system time in long string format, and then using the DIM command. • There were occasional crashes when switching layouts. • There were occasional crashes when performing a 3D rotate in drawings containing a point cloud. • There were occasional crashes when plotting to PDF using AccoreConsole.exe. • There were occasional crashes when performing an Undo after detaching a reference using the External References palette. • There were occasional crashes when PNG images were specified in a CUI resource file. Display • Xrefs on a frozen viewport layer would still be plotted. • AutoCAD in Citrix might not default to the primary display adapter. Open and Save •Opening a drawing file using an Excel hyperlink was repositioning the AutoCAD application window. PDF Import •Importing a PDF Underlay that was attached with relative path could fail. Xref • The Xref status incorrectly displays the "Needs reloading" message when the dataset is opened from a UNC path to a shared folder. General • When opening drawings created with AutoCAD Architecture, AutoCAD might crash if the drawing was saved again.
• Plotting with certain visual styles might produce incorrect results. • Migrating custom settings might fail. |
Zasláno: 03.srp.2016 v 17:28 |
Máte již nainstalován SP1 pro rodinu AutoCADu 2017 a pokud používáte profesní verzi AutoCADu 2017, tak i jeden z profesních Service Packů 1?V některých, poměrně vzácných případech může po instalaci SP1 nastat problém s načítáním add-on aplikací z Autodesk Apps. V těchto případech pomůže Autoloader Hotfix - viz
Stránka byla vygenerována za 0,473 sekund.
