Téma uzavřenoAutoCAD for Mac 2021.1
ARKANCE
Bodů: 22228
Přímý odkaz na tuto zprávu Téma: AutoCAD for Mac 2021.1
    Zasláno: 10.zář.2020 v 20:46
Byl uvolněn Update pro AutoCAD for Mac 2021 a AutoCAD LT for Mac 2021. Kromě podpory nového MacOS Big Sur (v11.0) přináší řadu dalších vylepšení. Ke stažení je na Autodesk Account.
Feature Enhancements
Drafting
  • Recent Input is now available on the shortcut menu.
AutoLisp Debugger
  • Enhancements include project management, support for extension level debug configurations, and easier LSP file loading.
Primary Issues Resolved by 2021.1 Update
macOS Big Sur Compatibility
  • UI layout problems in some palettes and dialogs.
  • UI string misaligned in some dropdown menus and popup lists.
  • DWG preview shows upside-down in Finder.
  • The horizontal toolbar color displays incorrectly.
  • System alert to grant access to some folder sometimes won't show up when opening a drawing with xrefs.
  • Occasional hangs when using Lisp Debugger.(Not available in LT)
Drafting
  • Occasional crashes when trim multiple objects.
  • Occasional crashes after edit scale list.
  • Occasional crashes when editing a drawing with tables.
  • Occasional crashes when editing a drawing with a lot of TrueType texts.
Blocks
  • Occasional short freezes when working in the block palette.
  • Occasional crashes when cancel in the delete block alert.
  • When using the -INSERT command with the Repeat Placement option, pressing Enter or the Spacebar now ends the command.
  • Occasional crashes when confirm attributes after inserting a block.
Install
  • AutoCAD Install constantly fails in a special situation.
Plot
  • Some full bleed paper sizes now available when printer set to None.
Quick Measure
  • Highlight color displays incorrectly when measure multiple areas.
  • The highlighted area using the Quick Measure option is now stable under custom UCS.
  • Improved performance when using Quick Measure in drawings with a lot of xrefs or TrueType texts.
Xref
  • Clicking on the notification to reload changed xrefs will not reload xrefs with unload status.
  • Improved performance when opening external references with XLOADCTL system variable set to 2.
  • Xref compare not working well in German and French version.
Others
  • Occasional crashes when open drawings.
  • Occasional crashes when search in Application Preferences dialog.
ARKANCE CZ - arkance.world
Tip 12853:Texty publikované z DWG na MacOS BigSur ztrácí tučné/kurzivní písmo.
Tip 12740:AutoCAD for Mac mi zobrazuje oříznuté hodnoty.
Tip 13100:Mohu provozovat AutoCAD na MacOS 12 Monterey?
Tip 8849:Kompatibilita AutoCADu for Mac s OS X 10.8 (Mountain Lion).
Tip 8392:Je AutoCAD 2012 for Mac kompatibilní s Mac OS X Lion?
Tip 11229:Mohu používat AutoCAD LT 2015/2016 na MacOS Sierra?
Stránka byla vygenerována za 0,367 sekund.
