Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4829:
Question
This message can appear on drawings converted from a non-Autodesk CAD program or created with an add-on application.
In the given view (viewport, layout) use the UCS W command to force the World UCS. Or try to change the drawing units. Also perform an audit of the complaining drawing (AUDIT, RECOVER).
ACAD
18.1.2006    19886×
Share the tip:
applies to: AutoCAD ·
Tip 14477:PurgeAll - automation of DWG file cleaning
Tip 11469:Why you should not use the DEFPOINTS layer to draw geometry?
Tip 10820:Unable to save to drawing c:\folder\filename.dxf
Tip 10612:Revit error: Unable to open because of unresolved pointer references​
Tip 9276:AutoCAD reports some xrefs as "Unresolved".
Back    All CAD Tips
Categ:
