CAD tip # 5804:
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 9870: | Xref NAME has multiple references. Not detached. |
Tip 9299: | What is the xref status "Unreferenced"? |
Tip 8499: | Batch change of page setups and purging in DWG files. |
Tip 6119: | Lost dynamic properties (grips) of dynamic blocks. |
How to bind Xrefs with the main drawing?
Edit blocks directly from table cells. « | » Model import error: Coincident face_face_ints with different body vertices
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
