  Visitors: 6132
CAD tip CAD tip # 12152:
Sketch lines linewidth - how to make Inventor lines thicker for a 4K display?
A - answer How to set Inventor to display thicker sketch lines for more distinct display on a hi-res monitor (e.g. 4K)?
Linewidth (thickness) of sketch lines is controlled by settings of a specific color scheme. Launch the Color scheme editor (since version 2019: Application options > Colors > Customize schemes, in older versions see Tip 10596) and in your preferred color scheme change the value Design > Sketch > Thick 3D line from the default value 2 e.g. to 3 or 4. Similarly you can change the value Thin 3D line.
The sketch display will then change from the default:
to a thicker appearance:
In older Inventor versions you can also use the Registry settings in the key:
HKCU\Software\Autodesk\Inventor\RegistryVersion2x.0\System\Preferences\ColorSchemes\Schemes\scheme#
e.g. to:
3DThickLine = 4
3DThinLine = 2
Inventor
24.2.2019    6837×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12326:How to customize your Fusion 360 background color? (any color theme)
Tip 12242:How to increase contrast between a constrained and underconstrained curve in an Inventor sketch?
Tip 10596:Changing colors of the Inventor color schemes (UI).
Tip 9387:How to change cursor color in the Inventor text editing window?
Tip 3623:How to modify color schemes offered in Inventor?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
