  Visitors: 9869
CAD tip CAD tip # 7627:
Where can I find the common shared Autodesk material library?
A - answer The common library of Autodesk rendering materials (Protein) for AutoCAD, Revit, Inventor, 3ds max and other CAD and multimedia applications of the 2011 family (installed with these products) is stored in the folder (fixed location):
C:\Program Files\Common Files\Autodesk Shared\Materials2011
and in 64-bit OS in the folder:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials2011
and the mapping files for texturing and bump maps then in the subfolders assetlibrary_base.fbm\Maps.
Since version 2012 you can find the "Autodesk Material Library" in the folder:
C:\Program Files\Common Files\Autodesk Shared\Materials\2012\ (etc.)
ACADRevitInventormax
7.11.2010    42232×
applies to: AutoCAD · Revit · Inventor · 3ds Max ·
Tip 14027:3D heart from the heart.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13095:How to change material texture orientation in Fusion 360?
Tip 12833:RAL color library (palette) for Fusion 360 (plus BS, AS, NCS).
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
