Caesar
Přihlášen: 15.čer.2006 Lokalita: Slovensko Používám: Revit 2016, AutoCAD 2016 Stav: Offline Bodů: 8 |
Téma: tvorba .shpZasláno: 15.čer.2006 v 21:40 |
caute vsetci cad manici
potreboval by som poradit ohladom tvorby vlastnych trochu zlozitejsich a nezvycajnych ciar... konkretne s tvorbou .shp suboru. ake programy (najlepsie free) na tvorbu tychto suborov pouzivate a viete odporucit? + by som poprosil zopar zakladnych veci ktore treba pri ich tvorbe dodrziavat dik |
Statik
Přihlášen: 08.čer.2006 Lokalita: Slovensko Používám: GStarrCAD Stav: Offline Bodů: 8 |
Zasláno: 15.čer.2006 v 22:33 |
Mas na mysli vytvorenie vlastneho fontu ?
tie sa definuju v SHP subore a potom sa kompiluju v ACADe 1/ Kazdy tvar musi mat jedinecne cislo 2/ Cisla 1-255 su rezervovane pre textove fonty. Ak vytvaras aj texty tak pouzi prave tie (podla ASCII) 3/ maximalna velkost jedneho tvaru je 2000 bytov Vytvaram ich priamo v textovom editore - NOTEPADe odporucam help pre ACAD pre blizsie specifikacie The following describes the fields of a shape description: shapenumber A number, unique to the file, between 1 and 258 (and up to 32768 for Unicode fonts), and preceded by an asterisk (*). Non-Unicode font files use the shape numbers 256, 257, and 258 for the symbolic identifiers Degree_Sign, Plus_Or_Minus_Sign, and Diameter_Symbol. For Unicode fonts these glyphs appear at the U+00B0, U+00B1 and U+2205 shape numbers and are part of the "Latin Extended-A" subset. Text fonts (files containing shape definitions for each character) require specific numbers corresponding to the value of each character in the ASCII code; other shapes can be assigned any numbers. defbytes The number of data bytes (specbytes) required to describe the shape, including the terminating 0. The limit is 2,000 bytes per shape. shapename The shape name. Shape names must be uppercase to be recognized. Names with lowercase characters are ignored and are usually used to label font shape definitions. specbyte A shape specification byte. Each specification byte is a code that defines either a vector length and direction or one of a number of special codes. A specification byte can be expressed in the shape definition file as either a decimal or hexadecimal value. This section uses both decimal and hexadecimal specification byte values for its examples (as do many of the shape definition files). If the first character of a specification byte is a 0 (zero), the two characters that follow are interpreted as hexadecimal values. |
AcadR10-AcadR2002
Zasláno: 15.čer.2006 v 23:10 |
Nejsnáze příkazem MAKESHP (z Express Tools).
Caesar
Zasláno: 18.čer.2006 v 15:49 |
tak som to skusal spravit pomocou mkshape, .shp to vytvorilo, ale ked som to chcel pouzit v ciare tak to z mne neznamych dovodov neslo
potrebujem vytvorit taketo nieco
ak by mi s tym vedel niekto pomoct budem vdacny za kazdu radu Upravil Caesar - 18.čer.2006 v 17:39 |
vbehun
Zasláno: 19.čer.2006 v 14:37 |
Ono SHP nejsou zrovna v oblibě, protože je musíte přbalit ke zdrojovému výkresu...
--- Toto je ta šipka (složená ze dvou symbolů, Z615 a Z659) --- ###.shp *255,14,Z670 3,2,13,(6,0,-43),(6,0,43),(0,0),4,2,0 *254,12,Z615 9,(1,0),(0,1),(2,-1),(3,0),(0,0),0 *253,15,Z659 3,4,5,8,(-4,3),6,5,8,(-4,-3),6,4,4,0 *252,5,Z660 7,254,7,253,0 --- ###.lin ;;Tvary car odpovidají CSN 01 3411 "Mapove znacky" *NN-C,- - - Z - - - Z - - - A,3,-1,3,-1,3,-1,[Z660,###.shx],-8 *NN-P,--------- Z --------- A,36,-1,[Z660,###.shx],-7 --- |
vbehun
Zasláno: 19.čer.2006 v 15:12 |
Teď koukám - ta Vaše šipka je poněkud jednodušší než ta v ukázce, stačilo by tedy modifikovat soubor SHP takto:
--- *250,3,x659 010,014,0 *251,10,x615 9,(1,0),(0,1),(2,-1),(0,0),0 *249,5,Z660 7,251,7,250,0 --- |
Caesar
Zasláno: 28.čer.2006 v 14:48 |
tu sipku sa mi vytvorit nepodarilo ale potrebujem vytvorit dalsie objetky... .sph subor si vytvorit viem, teda vytvori mi ho, ale ked ho "volam" pri robeni ciary v subore .lin, vypise mi "bad definition in...". .shp a .lin (samozrejme aj .shx) su v tom istom adresary, postupoval som aj podla heplu ale stale nic... uz fakt neviem co robim zle... skusal som to spojit do bloku, ale takto mi ten objekt nezobralo... nemal niekto podobny problem?
Buba
Zasláno: 28.čer.2006 v 15:03 |
Spustili ste si kompiláciu v AutoCADe? V nejakom článku to bolo super popísané. Ak to neviete rozchodiť, môžem poslať presnú linku. Ja som to vtedy zvládla na prvý raz podľa toho návodu. (Bolo to v článku na stránkach Xanadu samozrejme)
Buba
Zasláno: 28.čer.2006 v 15:07 |
Pardón, nie je to stránka Xanadu, ale z fóra mám na ňu LINK |
Mantlík
Zasláno: 28.čer.2006 v 15:15 |
A úplně triviální možnost - máte na ten adresář, kde jsou *.lin/*.shx nastavenou cestu ? Chybová hláška tomu může nasvědčovat Pokud to tím není, pak může být syntaktická chyba v souboru *.lin (anebo i *.shp) |
vbehun
Zasláno: 28.čer.2006 v 15:26 |
Chyba syntaxe v SHP souboru se projeví hned při kompilaci SHP > SHX. |
Caesar
tak pokial som zatial vypozoroval, tak ziadnu cestu mat nastavenu nemusim pokial mam .lin, .shx a .shp v jednom adresary, aspon zatial mi to ziadne problemy nerobilo a vsetko fungovalo korektne... najlepsie by uz asi bolo mat nejaky manual "pre debilov", lebo uz fakt neviem preco to nechce ist...
Buba
Zasláno: 28.čer.2006 v 15:42 |
Na tej linke, čo som Vám poslala jeden taký je. :-) |
Mantlík
Zasláno: 28.čer.2006 v 15:51 |
to caesar: to se mýlíte. Aby acad našel všechno, co potřebuje, musí k tomu znát cesty (nastavení v Nástroje -> Možnosti -> Soubory -> Cesta k podpůrným souborům) Lin a shx nemusí být v jednom adresáři, ale musí být v adresáři (adresářích), na které má acad nastavené cesty (a to záleží i na verzi acadu - obecně je hranicí 2005/2006). Pokud dotyčné (nefungující) soubory nemáte tam, co jiné (fungující) *.lin a *.shp, tak je tam překopírujte to behun: asi máte pravdu, ty shp jsem tam nakonec dopsal pro jistotu. Spíš to při načítání *.lin nemůže najít soubor *.shx anebo to je syntaxí |
Caesar
Zasláno: 28.čer.2006 v 17:14 |
dik za rady, vecer skusim...
Stránka byla vygenerována za 0,238 sekund.
tvorba .shp
Mantlík napsal(a):
