Téma: Aktualizace Revit 2022.1.2Zasláno: 29.led.2022 v 12:14 |
Byla vydána důležitá aktualizace pro Revit 2022 a Revit LT 2022 - update 2022.1.2. K dispozici je přes Desktop App nebo přes váš účet Autodesk Account. Obsahuje bezpečnostní aktualizace, aktualizace pro zlepšení stability některých funkcí, drobný fix pro Windows 11 a několik výkonnostních vylepšení.
Přehled oprav (zatím anglicky): Annotation - Text * Improved stability when loading families into the Revit model. Assembly * Improved stability when creating assemblies in Revit. Link Topography * Fixed an issue that linked topography could not be reloaded when using the Desktop Connector version 15.0.0.1540 or later. Link RVT Files * Improved performance during reload latest for models containing Revit links that include unloaded nested attached links. Materials * Improved the performance of AppearanceAssetElement editing API. MEP Miscellaneous * Fixed an issue where the new pipe segment in P&ID Browser failed to get created in a worksharing environment when there is an update from P&ID drawing. Options Dialog * Resolved an issue where editing Option>Check Spelling>Additional Dictionary does not work under Windows 11 environment. Project Browser * Improved stability when accessing the Measure Between Two References command in canvas. Revit Cloud Model (workshared) * Fixed an issue where some addins fail to load when Revit starts due to the publisher of the addin not being verified. * Fixed an issue where the Version History page was not available for models hosted in the EU region. * Fixed an issue where RevitAccelerator accumulates subscriptions to PubNub channels and thus causes performance degradation at PubNub service. Route Analysis * Resolved the issue that Route Analysis > One Way Indicator content does not work in localized Revit versions. Security * Addressed potential vulnerabilities throughout Revit. View Filters * Fixed the issue where 2D elements are missing in the Family Editor. View Templates * Improved Revit stability when restoring temporary view properties. |
Stránka byla vygenerována za 0,422 sekund.
