Téma uzavřenostyly *.STB
xicky Zobrazit panel
Přihlášen: 15.kvě.2005
Lokalita: Czechoslovakia
acad
Bodů: 52
Přímý odkaz na tuto zprávu Téma: styly *.STB
    Zasláno: 17.čer.2005 v 15:17
jak dostat v dialogu tisku styly*.stb?? nebo jak je dostat do nastavení stránky?
porad se mi zobrazuji pouze *.ctb
diky za radu
Rostislav Říha Zobrazit panel
Přihlášen: 03.říj.2004
ACA 2010
Bodů: 1620
Přímý odkaz na tuto zprávu Zasláno: 17.čer.2005 v 15:31
v options si musíte nastavit, které používáte, již hotový výkres lze pak překonvertovat přes convertpstyles
vbehun Zobrazit panel
Bodů: 1252
Přímý odkaz na tuto zprávu Zasláno: 17.čer.2005 v 15:34
Tak jak píše pan říha nebo podle nápovědy (pohříchu mohu posloužit pouze anglickou verzí)
Converting drawings using color dependent plot styles
to use named plot styles
Issue
You want to convert a drawing that utilizes color-dependent plot style tables to use named plot style tables.
Solution
To convert the drawing, use the CONVERTCTB and CONVERTPSTYLES commands.
1) Open the drawing you want to convert.
2) Type convertctb on the command line.
3) Select the color-dependent plot style table you want to convert.
4) Type convertpstyles on the command line. This converts a drawing that uses color-dependent plot style into a drawing that uses named plot styles.
5) Ignore the prompt about using the CONVERTCTB command, because you have done this already in steps 2 and 3. Choose OK in the warning dialog box.
6) Select the STB file you previously converted from a CTB file. This is the named plot style table you will use with the drawing.
Note: If you have not yet converted a color-dependent plot style table to named (steps 2 - 4) then you will be warned that the table you have picked in step 6 does not contain color mapping and the drawing cannot be converted.
Related Topics:
Applying named plot styles (STB files)
Converting drawings to use color-dependent plot styles
Recovering named plot styles after converting a drawing to color dependent mode
Tip 3604:Kdy je ve výkresu použit barevně závislý a kdy pojmenovaný výkresový styl?
Tip 14696:Jak přepnout DWG výkres mezi styly vykreslování CTB a STB?
Tip 7968:Černobílý tisk DWG výkresů z AutoCADu (i těch uložených z Inventoru).
Tip 4328:VIPDva způsoby nastavení více složek/umístění pro CTB/STB soubory.
Tip 2406:VIPJak jednoduše přenést obsah tabulky výkresových stylů do Excelu funkcemi čistého AutoCADu?
Tip 2404:Jak vytisknout obsah tabulky výkresových stylů CTB/STB?
Stránka byla vygenerována za 0,166 sekund.
