Téma: Revit 2014 Update 2Zasláno: 31.říj.2013 v 22:39 |
Byl uveden Update 2 (SP2) pro Revit 2014, všechny verze - tedy "one box", Architecture, Structure, MEP a LT. Ke stažení viz stránka Download.
Zasláno: 08.lis.2013 v 21:49 |
Přehled oprav v Update 2 (všechny verze Revitu 2014): Platform enhancements: * Disables the ability to paste spot elevations into a Sketch mode. Autodesk Revit Architecture 2014 Enhancements * Improves display of hidden lines on walls in Floor Plan and Elevation views. Autodesk Revit MEP 2014 Enhancements * Improves the visual fidelity of point clouds in MEP discipline views in regards to underlay elements in the view. Autodesk Revit 2014 Update Enhancement List * Removes the “Multiple Values” values for Flow, Velocity and Friction parameters and replaces it with the highest value applied to the entire segment length. Upravil Vladimír Michl - 10.lis.2013 v 09:33 |
Stránka byla vygenerována za 0,228 sekund.
Revit 2014 Update 2
