xicky
Přihlášen: 15.kvě.2005 Lokalita: Czechoslovakia Používám: acad Stav: Offline Bodů: 52 |
Téma: styly *.STBZasláno: 17.čer.2005 v 15:17 |
jak dostat v dialogu tisku styly*.stb?? nebo jak je dostat do nastavení stránky? porad se mi zobrazuji pouze *.ctb diky za radu |
Rostislav Říha
Zasláno: 17.čer.2005 v 15:31 |
v options si musíte nastavit, které používáte, již hotový výkres lze pak překonvertovat přes convertpstyles
Rostislav Říha
vbehun
Zasláno: 17.čer.2005 v 15:34 |
Tak jak píše pan říha nebo podle nápovědy (pohříchu mohu posloužit pouze anglickou verzí)
--- Converting drawings using color dependent plot styles to use named plot styles Issue You want to convert a drawing that utilizes color-dependent plot style tables to use named plot style tables. Solution To convert the drawing, use the CONVERTCTB and CONVERTPSTYLES commands. 1) Open the drawing you want to convert. 2) Type convertctb on the command line. 3) Select the color-dependent plot style table you want to convert. 4) Type convertpstyles on the command line. This converts a drawing that uses color-dependent plot style into a drawing that uses named plot styles. 5) Ignore the prompt about using the CONVERTCTB command, because you have done this already in steps 2 and 3. Choose OK in the warning dialog box. 6) Select the STB file you previously converted from a CTB file. This is the named plot style table you will use with the drawing. Note: If you have not yet converted a color-dependent plot style table to named (steps 2 - 4) then you will be warned that the table you have picked in step 6 does not contain color mapping and the drawing cannot be converted. Related Topics: Applying named plot styles (STB files) Converting drawings to use color-dependent plot styles Recovering named plot styles after converting a drawing to color dependent mode --- |
Stránka byla vygenerována za 0,418 sekund.
styly *.STB
