Téma uzavřenoUpdate 1 pro Inventor 2014
ARKANCE
Bodů: 22206
Přímý odkaz na tuto zprávu Téma: Update 1 pro Inventor 2014
    Zasláno: 09.kvě.2013 v 18:28
Byl uveden první hotfix pro Inventor 2014 (včetně Design Suites). Ke stažení na:
Přehled oprav:
Many duplicate occurrences shown in browser of IPN's following assembly demote/promote
Create New dialog does not remember the size and order of column in details view
Mass property is not available after migration
Min and Max values for Hole patching are not stored
View remains raster after selecting Precise view
iFeature insert dialog will show "Create Package" instead of the description of the iFeature
Copying a material in the category will corrupt that material from the library
Unable to change icon of existing custom category in Content Center Library
Adding a material will flag existing file as out of date and unnecessarily replace/update appearances
Weldment iAssemblies still looking for the obsolete "Use as Weldment Material" setting
Highlight effect when mouse hover on geometry is not as good as full mode when create Dimension/Baseline/Ordinate annotation in Raster View
GraphicsNode.RenderStyle has no effect on the graphics entity
The translator addin imports the DWG into sketch with wrong units if custom units specified
Legacy Section View displays incorrect line
Title block incorrectly displayed on Zoom when multiple files opened
Decreased performance when selecting all assets
Decreased performance when select Derive menu Other Tab
Slow shut down of InventorViewCompute.exe even after Inventor main window closes
Unexpected exit when make all views raster and make all views precise
Unexpected exit when switching to Full from Express mode
Unexpected exit when click adjust with customized project setting
Unexpected exit when rotating large assembly
Unexpected exit when dragging materials in user library
Unexpected exit when Load Express
Unexpected exit when starting Inventor from Factory Design Suite
Unexpected exit due to Non-transacted AddTriangleGraphics
ARKANCE CZ - arkance.world
maiklss Zobrazit panel
Přihlášen: 08.říj.2008
Lokalita: ČR (VY)
Inventor
Bodů: 1627
Přímý odkaz na tuto zprávu Zasláno: 09.kvě.2013 v 21:42
Kdy bude s Product designe suit v češtině k dispozici???< id="foxcub_translator_popup_win" style="visibility: ; width: 0px; height: 0px; border: 0px; padding: 0px;">
ARKANCE
Bodů: 22206
Přímý odkaz na tuto zprávu Zasláno: 10.kvě.2013 v 08:03
Vloni to bylo na začátku června, letos se očekává uvedení na konci května. Ale už dnes je možné část Product Design Suite 2014 počeštit instalací českého Language Packu pro Mechanical a pro Inventor - viz www.cadstudio.cz/download
Tip 9519:Nefunguje mi Inventor 2013, 2012 nebo 2011 po upgrade na Windows 8.1
Tip 9510:Chyba po spuštění Inventoru - Průzkumník Windows přestal pracovat, nebo Chyba aplikace.
Tip 9560:iLogic makro pro export IDW/DWG výkresu Inventoru do DXF.
Stránka byla vygenerována za 0,262 sekund.
