Téma uzavřenoRevit 2014 UR1
Bodů: 22272
Přímý odkaz na tuto zprávu Téma: Revit 2014 UR1
    Zasláno: 18.čvc.2013 v 15:20
Byla uvolněna "Update Release 1" (UR1, SP1) pro Autodesk Revit 2014.
Patch pro všechny verze Revitu 2014 (Architecture, MEP, Structure, one-box, LT) najdete zde na stránce Download. Na stránkách Autodesku se objeví v nejbližších dnech.
Bodů: 22272
Přímý odkaz na tuto zprávu Zasláno: 19.čvc.2013 v 08:38
Přehled aktualizací a oprav v UR1:
Autodesk® Revit® Architecture 2014 Enhancements
 Improves stability when using Trim/Extend tools with curtain walls.
 Improves stability when selecting Top Rail Type from with Project Browser.
 Improves stability when inserting Stairs.
 Improves stability when using the Split Element tool on walls.
Autodesk® Revit® Structure 2014 Enhancements
 Improves elevation assigned to beams when the elevation of a related beam system is adjusted.
 Improves graphics display of braces in course view when the justification parameter of the brace is adjusted.
 Improves graphics display of braces in course view when using a rotated crop region.
 Enables beams to be stretched using the Align tool.
 Improves stability when upgrading previous version structural projects.
Autodesk® Revit® MEP 2014 Enhancements
 Restores Revit MEP 2013 circuiting behavior when connecting panels together.
 Enables “Pick New Work Plane” ribbon tool for electrical equipment.
 Improves performance when selecting a piping system which contains a large number of elements.
 Improves stability when copying air terminals connected to duct segments.
 Improves stability when sizing Duct or Pipe systems.
 Improves stability when changing the type of Cable Tray or Conduit.
 Improves stability when editing type parameters from within the System Browser.
Autodesk® Revit® Platform 2014 Enhancements
 Allows Stairs, Railings and Wall Sweeps to be individual entities when exporting to FBX format.
 Improves data integrity of projects which contain RPC elements when exporting to FBX format.
 Improves categorization of parts when exported to FBX format.
 Improves performance when utilizing Render in Cloud functionality.
 Improves appearance of material textures when Rendering in Cloud.
 Improves graphics integrity of linked models when Rendering in Cloud.
 Allows Point Clouds to be visible when unchecking “Show Imported Categories in this View” display option.
 Maintains display order of filled regions which overlap solid hatches in projects that are upgraded to the Revit 2014 format.
 Corrects visual fidelity of objects in printed output which show as “Thin Lines” in drawing canvas.
 Improves consistency of displaying revisions within schedules.
 Improves data consistency of keynote legend when un-checking ‘Filter by Sheet’.
 Allows schedule footer text to follow column alignment.
 Improves stability when pasting elements between two Generic Model adaptive families.
 Improves stability when exporting project to Navisworks 2014.
 Improves stability during the loading of a family when utilizing either “Delete Element” or “Delete Type” option.
 Improves stability when placing details.
 Improves stability when a crop region is moved while the disjoin option is enabled.
 Improves data integrity during “Save As”.
 Improves stability when creating form elements.
 Improves stability when exiting Revit.
 Improves stability when printing Elevation and Detail views.
 Improves stability while editing groups.
 Improves stability when adjusting the elevation value of Levels.
 Improves stability when navigating in a project which contains linked point clouds.
 Improves stability when using the type selector within the properties palette.
 Improves stability when editing the layout of a schedule.
 Improves stability when adding a schedule to a sheet which has an active view.
 Improves stability when upgrading previous release projects.
 Improves stability when place a view on sheet.
UR1 je rovněž platformou pro další plug-in aktualizace, např. pro podporu IFC4.
Tip 9346:IFC4 export z BIM aplikace Autodesk Revit.
Tip 9780:Okno Autodesk Application Manager hlásí aktualizaci CAD aplikace.
Tip 10116:Mohu použít Revit Server určité verze pro ukládání projektů z Revitu jiné verze?
Tip 9560:iLogic makro pro export IDW/DWG výkresu Inventoru do DXF.
Stránka byla vygenerována za 1,727 sekund.
