Téma uzavřenoRevit 2014 Update 2
Bodů: 22238
Přímý odkaz na tuto zprávu Téma: Revit 2014 Update 2
    Zasláno: 31.říj.2013 v 22:39
Byl uveden Update 2 (SP2) pro Revit 2014, všechny verze - tedy "one box", Architecture, Structure, MEP a LT. Ke stažení viz stránka Download.
Bodů: 22238
Přímý odkaz na tuto zprávu Zasláno: 08.lis.2013 v 21:49
Přehled oprav v Update 2 (všechny verze Revitu 2014):
Platform enhancements:
*  Disables the ability to paste spot elevations into a Sketch mode.
*  Improves stability when using Results and Compare for Energy Analysis.
*  Improves stability when exporting to AutoCAD 2000 DWG format.
*  Improves Online Help experience by properly redirecting help inquiries to Autodesk Help.
*  Improves stability when enabling Sun Path.
*  Improves graphic display of Analytical Model Walls.
*  Improves data integrity of user defined parameters when utilizing temporary view templates.
*  Improves stability when editing dimensions.
*  Improves upgrade reliability of projects created with a different language version of Revit.
*  Improves stability when selecting materials within the Material Browser.
*  Restores the appearance of area color fills within linked files, when setting the view as By Linked View.
*  Improves stability when upgrading projects which utilize Keynotes.
*  Improves stability when importing IFC files.
*  Improves stability when editing Filters within the Visibility/Graphics Overrides dialog.
*  Improves stability when saving projects which were upgraded.
*  Improves stability when combining Phases.
*  Improves accuracy of Analytical Volumes.
*  Improves display of Imported Categories for DWG files linked into the project using the “Current View Only” option at time of import.
*  Improves stability when attempting to turn on sun path while temporary view properties mode is active.
*  Improves data integrity when export model to FBX.
*  Improves display of hidden lines on walls in Floor Plan and Elevation views.
Autodesk Revit Architecture 2014 Enhancements
Autodesk Revit Structure 2014 Enhancements
*  Improves display of vertical rebar when the rebar extends past the View Range.
*  Improves the location consistency of Structural beams when upgrading projects.
*  Improves stability when viewing a sheet which contains Structural Reinforcement Areas.
Autodesk Revit MEP 2014 Enhancements
*  Improves the visual fidelity of point clouds in MEP discipline views in regards to underlay elements in the view.
*  Improves connection reliability between fittings when upgrading MEP projects.
*  Improves connection reliability between fittings when changing the size of MEP elements.
*  Improves the data integrity of the Outside Air per Area value for a HVAC when exported to gbXML.
Autodesk Revit 2014 Update Enhancement List
*  Removes the “Multiple Values” values for Flow, Velocity and Friction parameters and replaces it with the highest value applied to the entire segment length.
Upravil Vladimír Michl - 10.lis.2013 v 09:33
Tip 9346:IFC4 export z BIM aplikace Autodesk Revit.
Tip 9116:Chybějící části kontextového ribbonu v Revitu 2013 a 2012.
Tip 13545:VIPInstalace Revit Update (nebo jiné aktualizace) končí chybou 101 (nebo jiným selháním)
Stránka byla vygenerována za 0,305 sekund.
