Přes 123.000 registrovaných u nás, celkem 1.126.000 registrovaných (CZ+EN).
ARKANCE Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: Implementujeme řešení Autodesk Stav: Offline Bodů: 22189 |
Téma: Hotfix Revit 2018.1.1Zasláno: 14.zář.2017 v 16:43 |
Byl uveden Hotfix 1 pro Revit 2018.1 (nový build: 20170907_2315). Ke stažení jej najdete na Autodesk Account nebo automaticky v Desktop App.
Přehled oprav: Platform * File Open/Save/Upgrade - Fixed an issue that could cause unresolved pointer references errors when opening files. * Materials - Fixed an issue that could cause instability in Revit when creating a new category in an external material library. - Improved stability when clicking twice quickly on the OK button in the Material Browser. - Fixed an issue that could cause instability when editing materials. * Sign In/Sign Out - Improved stability when signing out of an Autodesk account, then exiting and restarting Revit. * Startup/Save - Implemented better error handling to improve stability related to the Revit UI state. * User Interface - Fixed an issue that could cause menus to disappear from the ribbon after performing a print preview. * Worksharing - Improved stability in workshared files that contain sun and shadow settings saved in view templates. Architecture * Stair - Fixed an issue that could cause instability while upgrading projects that include Multistory Stairs. MEP * Duct - Fixed an issue that could cause instability in Revit when modifying the size of a set of pipe or duct elements. Structure * Rebar - Fixed an issue where the value of the rebar partition parameter was deleted when upgrading projects from Revit 2017 and earlier to Revit 2018. API - Fixed an issue so that the extents of a crop box are correctly set using the API. |
Stránka byla vygenerována za 0,438 sekund.
