Téma uzavřenoInventor HSM 2018.2 (R3)
Přímý odkaz na tuto zprávu Téma: Inventor HSM 2018.2 (R3)
    Zasláno: 04.říj.2017 v 20:43
Byla uvedena větší aktualizace pro CAM aplikaci Autodesk Inventor HSM 2018. Ke stažení je na Autodesk Account nebo přes Desktop App.
Přehled novinek:
This release contains a number of important fixes and improvements, as identified below.
  • Add “approach mode” parameter for 2d Contour. #6078
  • Add “Curve in Radius” parameter as an advanced setting for Adaptive Clearing. #8251
  • Added ‘Stock back’ as option for chuck position mode. #8280
  • Add Fixture Attachment selection to Setup for use by 3rd party software. #7937
  • Improved tool information for HTML setup sheet. #8098
  • Added ‘Chuck Front’ as possible reference for secondary spindle operations. #8160
  • Use new parametric confinement for Turning Part and Face. #8079
  • Added “Only Same Hole Depth” and “Only Same Z Top Height” to Drill when using “Select Same Diameter”. #8030
  • Added “Keep Original” option to Duplication and Component pattern. #8073
  • Only automatically select Setup Model bodies if there are few. #8140
  • Rename “WCS Probe” strategy to “Probe”. #7909
  • Add Renishaw Probes library to sample libraries. #8302
  • Changed default rounding for relative size cylindrical stock to 0. #7739
  • Set the focus of the Compare and Edit dialog to be the text filter on launch. #7908
  • Avoid showing Blend in “Create Derived Operation” submenu if not enabled by license. #8461
  • Fixed wrong toolpath issue for Turning Profile. #8219
  • Fixed potential break and retract for Adaptive Clearing when using entry positions. #8248
  • Fixed wrong linking issue for Turning Profile. #8253
  • Fixed potential failure for Turning Profile. #8267
  • Fixed issue with importing from TSV files. #8375
  • Fixed potentially missing model image for Excel 2007 Setup Sheet. #8351
  • Remove Delete command from context menu of browser item sub-nodes (toolpath, WCS, tool). #1229
  • Fixed issue where 2D contour using Dovetail could gouge the model. #8232
  • Fix incorrect toolpath in 2D Contour when using the Do Chamfer parameter. #8207
  • Selection button not auto-activated after make a previous selection. #3354
  • Fix cases where CAM browser doesn’t get updated properly when working with opened assembly component. #8081
  • Avoid license dialog when upgrading from previous version. #8090
  • Fixed crash trying to show preview on certain models. #8072
  • Fixed issue in 2D Chamfer where no vertical lead out radius was produced when “Same as lead in” is checked. #8041
  • Activate selection control when choosing “Selection” on heights tab. #3614
  • Hide Stock to Leave parameter for Turning Chamfer. #1465
Changes in Toolpath Generation
  • Added support for merging multiple contours when they are touching for turning. #6156
  • Improved support for predrilling for 2D Contour to support cases where tool size is very close to the pocket being machining. #7675
  • Changed turning to return error when multiple disjoint contours are provided. #6156
  • Improved retract linking for Turning Profile. #7498
  • Improved toolpath quality near rotary axis for Turning Profile. #7545
  • Fixed wrong retract issue for Turning Profile. #8253
  • Fixed wrong toolpath coordinate issue for Turning Profile. #8219
  • Fixed wrong retract issue for Turning Profile. #8198
  • Changed movement to using predrilling feed for Adaptive Clearing when using the predrill feature. #7743
  • Fixed issue when Adaptive Clearing would get stuck during calculation. #7327
  • Fixed potential failure for Turning Grooving. #7844
  • Fixed potential failure for Adaptive Clearing. #6587
  • Fixed issue with leads not remaining in fixed orientation when cutting at an angle for Turning Profile. #7782
  • Fixed retract exceeding clearance for Turning Profile. #7837
  • Fixed potential failure during staydown for Adaptive Clearing. #7825
  • Fixed potential failure for Adaptive Clearing. #7294
Changes to post processor:
  • Added API PostProcessor.registerTerminationHandler() to register functions to be called at end of processing.
  • Added API for multi-axis singularity settings. See MachineConfiguration.setSingularity() for details.
  • Fixed support for Unicode for ZipFile API. #7021
  • Fixed issue where toolpath information was not available during onTerminate().
Changes to post library:
  • Added Siemens 840D with subprograms post.
  • Added ACU-RITE MILLPWR G2 post.
  • Added support for product and holder links for HTML Tool Sheet.
  • Added Kern laser post.
  • Added new property ‘useTCPC’ to switch between TCP and no-TCP for HAAS Next Generation posts.
  • Added support for accumulated depth for the G73 canned cycle for HAAS mill posts.
  • Detect and present product ID for tool and holder as link for HTML setup sheet.
  • Improved CAMplete post for better support of installed CAMplete.
  • Added DMS router FAGOR 8055 & 8065 posts.
  • Added property ‘writeComments’ to enable/disable comments for Maho 432 post.
  • Added CNC Router Parts Mach3 plasma post.
  • Added post for Maho Philips 432.
  • Added Mach3 waterjet and plasma posts.
  • Updated support for G112/XZC machining for HAAS mill-turn posts.
  • Added ProtoTRAK turning post.
  • Added G48 support for CSS mode for Mach3 turning post.
  • Added support for switching to mm/s using property ‘useUnitPerSecondFeedrates’ for WinPC-NC. The default is mm/min. This feature is only supported for metric mode.
  • Added support for turning off rigid tapping using property ‘useRigidTapping’ for Fadal post. Rigid tapping is enabled by default.
  • Added support for laser cutting for UCCNC post.
  • Added property ‘abrasiveFlow’ for Hydren waterjet post.
  • Updated properties for specifying the machine model for Roland RML post.
  • Updated properties for specifying the fourth axis for UCCNC posts.
  • Updated properties for specifying the fourth axis for WinPC-NC posts.
  • Added properties to tell which rotaries are available to avoid G28 retracts when not desired for HAAS Next Generation posts.
  • Updated when to use the chip breaking and deep drilling canned cycles for Anilam ISO post.
  • Don’t show number of flutes if 0 for HTML Setup Sheet.
  • Updated MultiCam HPGL post to only accept 3-axis toolpath.
  • Ignore work offset for Roland post.
  • Updated MultiCam ISO post to only accept 3-axis toolpath.
  • Updated FlexiCAM post to only accept 3-axis toolpath.
  • Updated documentation for properties for posts.
  • Added failure when not using machine rotaries for multi-axis simultaneous toolpath for posts.
  • Adjusted encoder reset at rewinds for HAAS UMC-750 post.
  • Adjusted rewind handling for HAAS with trunnion post.
  • Updated support for floating tab holder for Andronic post.
  • Changed description for HTML Setup Sheet.
  • Updated retract handling for Heidenhain posts.
  • Simplified implementation of Flow post.
  • Renamed property ‘rigidTapping’ to ‘useRigidTapping’ for Heidenhain posts.
  • Changed defaults for properties and added support for enabling/disabling multi-axis for CR Onsrud router post.
  • Major update of ISEL post.
  • Updated tool info for HTML Setup Sheet and enabled tool list by default.
  • Updated description for HAAS milling posts to include ‘(pre-NGC)’ to indicate that posts are for the pre-Next Generation Control.
  • Updated multi-axis support for Pocket NC, 5AXISMAKER, and HAAS posts.
  • Updated inverse time support for HAAS posts.
  • Updated inverse time support for Tormach PathPilot, Pocket NC, 5AXISMAKER, and Fadal posts.
  • Updated inverse time support for Fanuc with A-axis post.
  • Fixed wrong rotation for 5-axis indexing when tool axis is perpendicular to the slave table for Pocket NC.
  • Fixed canned cycles output for Anilam ISO post.
  • Use 6 decimals for to multi-axis vectors when no machine is defined for Siemens 840 posts.
  • Fixed G18 issue for polar interpolation mode for Doosan mill-turn post.
  • Fixed naming for property ‘spindleSpeedInRPM’ for Roland RML post.
  • Fixed potential failure for Heidenhain 407 post.
  • Fixed issue with failure for HAAS mill-turn posts.
  • Fixed missing axis limit for PLANE SPATIAL for Heidenhain  and Heidenhain 426 posts.
  • Fixed missing spindle and coolant on command for rewind situations for HAAS mill-turn posts.
  • Fixed potentially missing model picture issue for Excel 2007 Setup Sheet.
  • Fixed wrong initial position issue for Brother post.
  • Fixed C-axis positioning for axial center drilling for HAAS mill-turn posts.
  • Fixed multi-axis support for Doosan mill-turn post.
  • Fixed issue with out of range C-axis for XZC milling for HAAS lathe posts.
  • Fixed G43.4 for Doosan VMC Fanuc post.
  • Fixed multi-axis indexing issue for HAAS posts.
  • Fixed unsupported G90/G91 for Mach4 turning post.
  • Fixed support for property ‘useZ’ at cycles for Torchmate post.
  • Fixed wrong syntax for cycles for XML post.
  • Fixed power-off support for nozzle down moves for Flow post.
  • Fixed tangency validation for Thermwood post.
  • Fixed missing EOT at program end for Maho 432 post.
  • Fixed slow positioning moves for canned cycles for Fadal post.
  • Fixed circular moves in ZX plane for ISEL post.
  • Fixed missing G43.4 TCP output for Fanuc posts.
  • Fixed subprogram issues for Heidenhain post.
  • Fixed missing length offset for Siemens 802D/810D posts. Note that length offset is always set to D1.
  • Fixed backwards compatibility issue for HAAS mill-turn posts.
  • Fixed G94 output for Fanuc with A-axis post.
  • Fixed position issue for subprogram for Fanuc post.
  • Fixed missing D-word with G41/G42 for Hydren Systems waterjet post.
  • Fixed missing output of main/sub spindle for axial center drilling for Mazak Integrex post.
  • Fixed issue for CSS mode for Siemens mill-turn post.
  • Fixed coolant handling for Tormach post.
  • Updated smoothing and fixed multi-axis support for Onsrud post.
  • Fixed turning output after drilling for Doosan mill-turn post.
  • Fixed inverse time support for Mach mill posts.
  • Disabled G2/G3 since unsupported for Carvey.
Tip 11403:VIPNC Editor se simulací kódu i ve verzi 2018.
Tip 354:Chyba v UTIL.DLL a BMM.DLL při spuštění MAXe R3.
Tip 12502:VIPJak přidat nový postprocesor do Inventor CAM (HSM)
Tip 11383:VIPJak získat souřadnice obráběcí cesty z CAM aplikace Inventor HSM v CSV nebo DXF?
Tip 10132:Distribuovaný výpočet CAM úlohy v Inventor HSM.
Tip 12578:VIPInventor CAM funguje po instalaci jen v režimu Express
