Téma uzavřenoAktualizace AutoCAD 2018.1.2
Bodů: 22229
Přímý odkaz na tuto zprávu Téma: Aktualizace AutoCAD 2018.1.2
    Zasláno: 19.bře.2018 v 18:13
Byla uvedena aktualizace 2018.1.2 pro AutoCAD (včetně profesních verzí) a AutoCAD LT. Ke stažení je v Autodesk Account nebo pomocí Desktop App.
Přehled oprav:
* Point Cloud
- Occasional crashes when adding color schemes to point clouds no longer occur.
* General
- Occasional crashes when detaching external references in some visual styles no longer occur.
- Occasional crashes when importing or attaching DGN drawings with some spline types no longer occur.
- Occasional crashes when getting the UCS coordinate values from a dimension no longer occur.
* Display
- The image of a Web URL in the drawing displays correctly.
* Model Documentation
- No error dialog box displays after completing certain Model Documentation commands.
* MText
- The characters show correctly when using double-byte characters with certain settings.
* PDF / Plot
- PDF files plotted using certain visual styles display correctly.
- The plot result remains correct after changing the visual style in model space.
* General
- Object snap settings remain turned on during view editing commands.
- AutoCAD startup time and network drive scanning speed are improved.
- The dynamic input tooltips for dimensions display correctly on all supported operating systems.
Tip 11771:VIPHavárie Vault Basic 2018.2 - nastavení pracovní složky
Tip 11473:Chyba: Sorry, this pre-release product has expired.
Tip 9940:Jde do Revitu načíst SKP soubory ze SketchUp 2013, 2018, 2019 či 2020?
Tip 11167:Problém AutoCADu ve Windows 10 Anniversary Update (klávesa F8).
Tip 11786:Chybějící povrchy v modelu v Revit Live 2018.2.
Tip 12433:Instalace se nezdařila - Update AutoCAD 2020.1.2
