ARKANCE Přihlášen: 09.zář.2004 Lokalita: ČR (JČ) Používám: Implementujeme řešení Autodesk Stav: Offline Bodů: 22206 |
Téma: Inventor 2014 Update 2Zasláno: 10.čvc.2013 v 08:14 |
Pro uživatele Inventoru 2014 byl uvolněn hotfix "Update 2" - http://usa.autodesk.com/getdoc/id=DL21901957
Obsahuje i opravy z "Update 1", je určen pro samostatný Inventor i sady Design Suite 2014 a opravuje následující chyby:
Older VBA code is not working properly Shaded views are not showing correct in drawing with zoom Inconsistant behavior when Copy and Paste of components where file path is long Layout constraint context menu command is missing One side of brake line show unshaded when creating break in a shaded projected view Bolted connection is not able to machine more than two parts at the same time Unexpected exit when Loading idw Stability enhancement Update 1: Many duplicate occurrences shown in browser of IPN's following assembly demote/promote Create New dialog does not remember the size and order of column in details view Mass property is not available after migration Min and Max values for Hole patching are not stored View remains raster after selecting Precise view iFeature insert dialog will show "Create Package" instead of the description of the iFeature Copying a material in the category will corrupt that material from the library Unable to change icon of existing custom category in Content Center Library Adding a material will flag existing file as out of date and unnecessarily replace/update appearances Weldment iAssemblies still looking for the obsolete "Use as Weldment Material" setting Highlight effect when mouse hover on geometry is not as good as full mode when create Dimension/Baseline/Ordinate annotation in Raster View GraphicsNode.RenderStyle has no effect on the graphics entity The translator addin imports the DWG into sketch with wrong units if custom units specified Legacy Section View displays incorrect line Title block incorrectly displayed on Zoom when multiple files opened Decreased performance when selecting all assets Decreased performance when select Derive menu Other Tab Slow shut down of InventorViewCompute.exe even after Inventor main window closes Unexpected exit when make all views raster and make all views precise Unexpected exit when switching to Full from Express mode Unexpected exit when click adjust with customized project setting Unexpected exit when rotating large assembly Unexpected exit when dragging materials in user library Unexpected exit when Load Express Unexpected exit when starting Inventor from Factory Design Suite Unexpected exit due to Non-transacted AddTriangleGraphics |
Stránka byla vygenerována za 0,381 sekund.
