Téma uzavřenotvorba .shp
Caesar Zobrazit panel
Přihlášen: 15.čer.2006
Lokalita: Slovensko
Revit 2016, AutoCAD 2016
Bodů: 8
Přímý odkaz na tuto zprávu Téma: tvorba .shp
    Zasláno: 15.čer.2006 v 21:40
caute vsetci cad manici
potreboval by som poradit ohladom tvorby vlastnych trochu zlozitejsich a nezvycajnych ciar... konkretne s tvorbou .shp suboru. ake programy (najlepsie free) na tvorbu tychto suborov pouzivate a viete odporucit? + by som poprosil zopar zakladnych veci ktore treba pri ich tvorbe dodrziavat
dik
Statik Zobrazit panel
Přihlášen: 08.čer.2006
Lokalita: Slovensko
GStarrCAD
Bodů: 8
Přímý odkaz na tuto zprávu Zasláno: 15.čer.2006 v 22:33
Mas na mysli vytvorenie vlastneho fontu ?
tie sa definuju v SHP subore a potom sa kompiluju v ACADe
1/ Kazdy tvar musi mat jedinecne cislo
2/ Cisla 1-255 su rezervovane pre textove fonty. Ak vytvaras aj texty tak pouzi prave tie (podla ASCII)
3/ maximalna velkost jedneho tvaru je 2000 bytov
Vytvaram ich priamo v textovom editore - NOTEPADe
odporucam help pre ACAD pre blizsie specifikacie
The following describes the fields of a shape description:
shapenumber
A number, unique to the file, between 1 and 258 (and up to 32768 for Unicode fonts), and preceded by an asterisk (*). Non-Unicode font files use the shape numbers 256, 257, and 258 for the symbolic identifiers Degree_Sign, Plus_Or_Minus_Sign, and Diameter_Symbol. For Unicode fonts these glyphs appear at the U+00B0, U+00B1 and U+2205 shape numbers and are part of the "Latin Extended-A" subset.
Text fonts (files containing shape definitions for each character) require specific numbers corresponding to the value of each character in the ASCII code; other shapes can be assigned any numbers.
defbytes
The number of data bytes (specbytes) required to describe the shape, including the terminating 0. The limit is 2,000 bytes per shape.
shapename
The shape name. Shape names must be uppercase to be recognized. Names with lowercase characters are ignored and are usually used to label font shape definitions.
specbyte
A shape specification byte. Each specification byte is a code that defines either a vector length and direction or one of a number of special codes. A specification byte can be expressed in the shape definition file as either a decimal or hexadecimal value. This section uses both decimal and hexadecimal specification byte values for its examples (as do many of the shape definition files). If the first character of a specification byte is a 0 (zero), the two characters that follow are interpreted as hexadecimal values.
AcadR10-AcadR2002
Bodů: 22272
Přímý odkaz na tuto zprávu Zasláno: 15.čer.2006 v 23:10
Nejsnáze příkazem MAKESHP (z Express Tools).
Lokalita: Slovensko
Bodů: 8
Přímý odkaz na tuto zprávu Zasláno: 18.čer.2006 v 15:49
tak som to skusal spravit pomocou mkshape, .shp to vytvorilo, ale ked som to chcel pouzit v ciare tak to z mne neznamych dovodov neslo
potrebujem vytvorit taketo nieco
ak by mi s tym vedel niekto pomoct budem vdacny za kazdu radu
Upravil Caesar - 18.čer.2006 v 17:39
vbehun Zobrazit panel
Přihlášen: 04.říj.2004
Lokalita: ČR (ZL)
Bodů: 1252
Přímý odkaz na tuto zprávu Zasláno: 19.čer.2006 v 14:37
Ono SHP nejsou zrovna v oblibě, protože je musíte přbalit ke zdrojovému výkresu...
Toto je ta šipka (složená ze dvou symbolů, Z615 a Z659)
###.shp
*255,14,Z670
3,2,13,(6,0,-43),(6,0,43),(0,0),4,2,0
*254,12,Z615
9,(1,0),(0,1),(2,-1),(3,0),(0,0),0
*253,15,Z659
3,4,5,8,(-4,3),6,5,8,(-4,-3),6,4,4,0
*252,5,Z660
7,254,7,253,0
###.lin
;;Tvary car odpovidají CSN 01 3411 "Mapove znacky"
*NN-C,- - - Z - - - Z - - -
A,3,-1,3,-1,3,-1,[Z660,###.shx],-8
*NN-P,--------- Z ---------
A,36,-1,[Z660,###.shx],-7
Lokalita: ČR (ZL)
Bodů: 1252
Přímý odkaz na tuto zprávu Zasláno: 19.čer.2006 v 15:12
Teď koukám - ta Vaše šipka je poněkud jednodušší než ta v ukázce, stačilo by tedy modifikovat soubor SHP takto:
*250,3,x659
010,014,0
*251,10,x615
9,(1,0),(0,1),(2,-1),(0,0),0
*249,5,Z660
7,251,7,250,0
Lokalita: Slovensko
Bodů: 8
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 14:48
tu sipku sa mi vytvorit nepodarilo ale potrebujem vytvorit dalsie objetky... .sph subor si vytvorit viem, teda vytvori mi ho, ale ked ho "volam" pri robeni ciary v subore .lin, vypise mi "bad definition in...". .shp a .lin (samozrejme aj .shx) su v tom istom adresary, postupoval som aj podla heplu ale stale nic... uz fakt neviem co robim zle... skusal som to spojit do bloku, ale takto mi ten objekt nezobralo... nemal niekto podobny problem?
Buba Zobrazit panel
Přihlášen: 05.říj.2005
Lokalita: Slovensko
AEC Collection
Bodů: 1692
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:03
Spustili ste si kompiláciu v AutoCADe? V nejakom článku to bolo super popísané. Ak to neviete rozchodiť, môžem poslať presnú linku. Ja som to vtedy zvládla na prvý raz podľa toho návodu. (Bolo to v článku na stránkach Xanadu samozrejme)
Buba Zobrazit panel
Lokalita: Slovensko
AEC Collection
Bodů: 1692
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:07
Pardón, nie je to stránka Xanadu, ale z fóra mám na ňu LINK
http://mujweb.cz/Pocitace/alfred/lines.htm
Mantlík Zobrazit panel
Přihlášen: 01.říj.2004
ACAD/Map/Civil R10-> 2026
Bodů: 2595
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:15
A úplně triviální možnost - máte na ten adresář, kde jsou  *.lin/*.shx nastavenou cestu ? Chybová hláška tomu může nasvědčovat
Pokud to tím není, pak může být syntaktická chyba v souboru *.lin (anebo i *.shp)
J. Mantlík
Lokalita: ČR (ZL)
Bodů: 1252
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:26
Původně odeslal(a) Mantlík Mantlík napsal(a):
Chyba syntaxe v SHP souboru se projeví hned při kompilaci SHP > SHX.
Lokalita: Slovensko
Bodů: 8
tak pokial som zatial vypozoroval, tak ziadnu cestu mat nastavenu nemusim pokial mam .lin, .shx a .shp v jednom adresary, aspon zatial mi to ziadne problemy nerobilo a vsetko fungovalo korektne... najlepsie by uz asi bolo mat nejaky manual "pre debilov", lebo uz fakt neviem preco to nechce ist...
Buba Zobrazit panel
Lokalita: Slovensko
AEC Collection
Bodů: 1692
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:42
Na tej linke, čo som Vám poslala jeden taký je. :-)
Bodů: 2595
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 15:51
to caesar:
to se mýlíte. Aby acad našel všechno, co potřebuje, musí k tomu znát cesty (nastavení v Nástroje -> Možnosti -> Soubory -> Cesta k podpůrným souborům)
Lin a shx nemusí být v jednom adresáři, ale musí být v adresáři (adresářích), na které má acad nastavené cesty (a to záleží i na verzi acadu - obecně je hranicí 2005/2006). Pokud dotyčné (nefungující) soubory  nemáte tam, co jiné (fungující) *.lin a *.shp, tak je tam překopírujte
to behun:
asi máte pravdu, ty shp jsem tam nakonec dopsal pro jistotu. Spíš to při načítání *.lin nemůže najít soubor *.shx anebo to je syntaxí
J. Mantlík
Lokalita: Slovensko
Bodů: 8
Přímý odkaz na tuto zprávu Zasláno: 28.čer.2006 v 17:14
dik za rady, vecer skusim...
Tip 6527:Import SHP souborů, stylizace zobrazení a topologická analýza v AutoCADu Map.
Tip 6235:VIPExport .SHP souboru z Civil 3D skončí kritickou chybou.
Tip 2035:VIPJak změnit výšku vrstevnic dle objektových dat se Z souřadnicí?
Tip 5471:Mohu v Mapu editovat .SHP soubory ArcView?
Tip 6845:Export SHP souborů z Civil 3D 2010 je prázdný.
Tip 12750:VIPPostup exportu Oborového modelu do SHP.
Stránka byla vygenerována za 0,375 sekund.
