Téma uzavřenoAktualizace Vault 2022.3
Bodů: 22272
Přímý odkaz na tuto zprávu Téma: Aktualizace Vault 2022.3
    Zasláno: 13.dub.2022 v 18:14
Byla vydána aktualizace pro PDM aplikaci Autodesk Vault 2022. Update 2022.3 je potřeba jako vždy instalovat na server i na stanice. Pokud používáte nadstavby Vaultu nebo propojení s ERP, doporučujeme pro instalaci kontaktovat naše techniky.
Přehled oprav:
API
Added Inventor 2022 Interop update in Vault. PDM-35502
Add-ins: ACAD
Resolved issue where checking in DWG to Vault failed with an error. PDM-35874
Add-ins: Inventor
Resolved issue where the Inventor crashed when trying to check in assemblies with level of detail (LOD) substitutes to Vault 2022.2.2. PDM-36305
Resolved issue where the Vault prompt for updating properties on File edit in Inventor wasn’t showing after check out prompt. PDM-36013
Resolved the IDW file checkin issue in Vault. PDM-36334
Fixed performance issue observed while checking in the assembly in Vault. PDM-35168
Resolved the equivalence error displayed for the file Revision property when mapping to the item and file property. PDM-35936
Resolved issue where the Inventor crashed when trying to check in assemblies with level of detail (LOD) substitutes to Vault 2022.2.2. PDM-36304
Behaviors
Resolved issue where importing Factory CFG file into existing Vault in the ADMS Console changes existing settings for lifecycles, revisions, and properties. PDM-36343
Client
Resolved issue with boolean UDP mapped to text file property in mixed client/server languages. PDM-35528
Resolved issue where the Privacy statement blocked the user from logging into Vault. PDM-35890
Resolved issue where the focus changes from the original search folder when opening Excel documents from My Search Folders. PDM-35579
Resolved issue where the measure tool in the Autodesk Viewer wasn’t working for all DWF files in Vault. PDM-35859
Resolved issue where the LMV viewer was used instead of default viewer for pdf set in "Document Previewer options" in Vault. PDM-36257
Resolved issue where Synchronize Properties with item properties doesn't create iProperties in the file. PDM-35596
Resolved issue where the Autodesk Viewer failed to load the pdf file with space in its name. PDM-35650
Resolved issue where the Privacy statement blocked the user from logging into Vault. PDM-35745
Items
Resolved issue where Item properties weren’t synchronizing to the drawing in the Vault. PDM-35280
Resolved issue where the update item associated wrong file reference to the file with model states. PDM-35718
Resolved issue with non-compliance property seen in the item write back workflow. PDM-35600
Resolved issue where a timeout error occurred while updating Item using the Administrator account in the Vault Client. PDM-36020
Resolved issue where Item properties weren’t synchronizing to the drawing in the Vault. PDM-35638
Job Processor
Resolved issue where an error occurred on attempting to create PDF from released IDW file using Job Processor. PDM-35535
Resolved issue where the drawing failed to publish a PDF after editing a subcomponent. PDM-33673
Server
Resolved a server connection issue where the Vault was installed on a custom port. PDM-34997
Resolved issue where executing Update Domain Group removed the Display template when a user was removed from a group for that user. PDM-35484
Thin Client
Resolved issue with the viewing of files in Autodesk viewer where white lines weren’t seen properly. PDM-35417
Resolved issue with changing of Vaults in Thin Client when the user with groups is used. PDM-35241
Resolved issue with the viewing of image files in Thin Client. PDM-35973
Tip 13235:Jak do PowerMill načíst modely ve formátu Solidworks 2022 nebo Solid Edge 2022?
Tip 12964:Nefunguje procházení složek ve web klientu Autodesk Vault.
Tip 14049:Proč mi export z Civilu 3D do IFC 4.3 neexportuje povrchy a tělesa?
Tip 12929:Mohu použít Inventor 2022 s PDM systémem Vault 2021?
Tip 13447:Jak do PowerMill načíst modely ve formátu Creo 9.0 nebo CATIA V5-6R2022?
Tip 13322:Nelze získat platnou licenci - aktualizace Holixa T4R v3.3.1
Stránka byla vygenerována za 0,471 sekund.
