Téma uzavřenoRevit 2017.2
Bodů: 22240
Přímý odkaz na tuto zprávu Téma: Revit 2017.2
    Zasláno: 27.led.2017 v 23:00
Na Autodesk Accounts je ke stažení aktualizace pro Revit 2017 - verze 2017.2 obsahuje tyto funkce a opravy:
2017.2 Update
  • Platform
    • Collaboration for Revit
      • Includes assorted fixes to improve service and data reliability.
    • Align
      • Improves stability when aligning structural elements in plan view.*
    • Annotation
      • Corrects an issue with scaling of the Operating System text, so that it no longer has any effects text within a view.*
      • Improves stability when using calculated parameter in an annotation tag label.*
    • Family
      • Corrects an issue where instances of shared nested families were not updating when more than one level deep.*
      • Corrects an issue which prevented type duplication of families with shared project parameters associated to formula driven family parameters.*
    • File Open/ Save/ Upgrade
      • Corrects an issue which causes model corruption when enabling work-sharing and replacing an existing model.*
      • Improves stability when opening project which contains model corruption.*
      • Improves stability when opening a project with 'Constrain to routing preferences' filter checked.*
    • Graphics
      • Improves stability when you by double-click to edit a family from the Work Plane Viewer.*
    • Import/Export
      • Improves stability when opening the Workset dialog, and the model was not saved successfully.*
      • Corrects the display of some imported DWG files in section views.*
      • Adds the option to set the color for the hatch pattern background when exporting to DWG/DXF.
      • Adds the option to export to DWG/DXF and DGN in True Color (RGB Values), as specified in the view.
    • Keynotes
      • Corrects an issue in which Keynotes By Sheet could lose their numerical value.*
    • Materials
      • Improves stability when working with the Material Browser and Paint tool.*
    • Projects
      • Improves stability when mirroring a project.*
      • Improves stability when Load Types are copied between projects or transferred with project standards.*
    • Options
      • Corrects an issue which prevented a newly added path in the Options dialog from being saved correctly.*
      • Improves stability when adding keyboard shortcuts for a command with an empty Paths field.*
    • Rendering
      • Corrects an issue where an error message was presented when rendering with a transparent background in the cloud.*
    • User Interface
      • For the UK terminology, corrects missing User Interface components which were introduced with Revit 2017.1 update.*
      • Improves stability when right clicking on the drop down list when changing a view reference.*
      • Changes the keyboard shortcut for the Location tool from "L" to "O" in the Manage and Analyze tabs to avoid a conflict.*
      • Corrects an issue in which the Space Naming tool dialog display did not scale correctly when DPI is set above 100%.*
    • WorkSharing
  • MEP
    • Electrical
      • Corrects an issue that could cause Revit to hang when creating a circuit with a wire type using a material of 0A for sizing.*
    • Fabrication
      • Corrects an issue with route and fill when finding solutions for vertical risers.*
    • Piping
      • Improves stability when adding a fitting to a piping network.*
  • Structural
    • Reinforcement
      • Improves the performance of Multiple Rebar Annotation on rebar sets.*
    • Structural Families
      • Corrects an issue during upgrade of project which caused the loss of associated parameters to Offsets in Structural Foundations.*
                • Platform
            • Align
            • Annotation
            • Family
            • Graphics
            • Import/Export
            • Keynotes
            • Materials
            • Projects
            • Options
            • Rendering
            • User Interface
            • WorkSharing
          • MEP
            • Electrical
            • Fabrication
            • Piping
          • Structural
            • Reinforcement
          Peter Jirat Zobrazit panel
          ACAD ->2021, Revit ->2022
          Bodů: 3946
          Přímý odkaz na tuto zprávu Zasláno: 30.led.2017 v 09:40
          Tak jsem vyzkoušel, zda už není odstraněná reportovaná chyba http://www.cadforum.cz/forum/forum_posts.asp?TID=22689&title=chyba-ve-vykazech
          a zatím nic Angry . Může někdo z betatesterů vyzkoušet, jestli to v 2018 už odstranili? Jinak je celé vykazování materiálů na vodě.
          Díky
          Bodů: 3946
          Přímý odkaz na tuto zprávu Zasláno: 30.led.2017 v 13:55
          Připojené náhledyPřihlaste se pro zobrazení plné verze - 74/chyba2.JPG
          Chápu, že mám málo izolace, že nemám žádnou izolaci, ale záporné množství objemu materiálu? To jako že něco dlužím? Jsou to jen dvě podlahy přes sebe.
          sonicer Zobrazit panel
          Přihlášen: 20.čvc.2005
          Revit, Autocad, Navisworks
          Bodů: 223
          Přímý odkaz na tuto zprávu Zasláno: 30.led.2017 v 16:55
          Uvedená chyba je špatný mezi výpočet a předání dat do tabulky.
          Když si stěnu rozložíte na parts. Tak při kliknutí na určitou vrstvu jsou ve vlastnostech objemy  stále správně...Jen v tabulce je špatně hodnota.;)
          BimRvt.cz
          Přímý odkaz na tuto zprávu Zasláno: 30.led.2017 v 17:59
          Ahoj Petře,
          mohl by jsi mi prosím poslat soubor, kde to máš nasimulováno?  Zkusím to jak bude chvilka ve 2018.
          Bodů: 223
          Přímý odkaz na tuto zprávu Zasláno: 30.led.2017 v 19:20
          BimRvt.cz
          Bodů: 3946
          Přímý odkaz na tuto zprávu Zasláno: 31.led.2017 v 09:25
          Původně odeslal(a) sonicer sonicer napsal(a):
          Viz. odkaz
          http://help.autodesk.com/view/RVT/2016/CSY/?guid=GUID-F8270A42-CA71-46C7-B145-85EC2CB8E4A1
          text v poznámce;)
          Díky, ale k rozdílům dochází vždy, když spojíte dvě stěny, z nichž jedna má více než dvě vrstvy. To podle mne není odhadem kvůli výkonu, ale chybou v programu. Nebo můžeme ke každému projektu přidávat i odkaz na help, kde to klientovi zdůvodníte (nám se stalo, že klient na takovouto chybu odhadu přišel).
          Parts sice vykazují přesné údaje o objemu, ale nedají se vždy použít, ne vše lze na Parts převést, není to živý element, musíte mít nad nimi dohled, a výrazně zatíží velké modely. A i Parts mají problém, ale zas s vykazovanou plochou materiálů...
          Tip 11098:Popisky ozdobným písmem v Revitu na Win10.
          Tip 11333:Jak publikovat projekt z Revitu do BIM 360 Glue?
          Tip 11180:Nejde mi spustit Dynamo pro Advance Steel.
          Stránka byla vygenerována za 0,471 sekund.
